Thanks my man!Interesting little watch
This type of watch is the Swiss equivalent of the Dollar watches, actually even cheaper.
The dial is in metal; the writings and hours are painted. The writings Railway Keeper, Robust, and specially examined are only marketing.
The movement is a so-called calibre Roskopf with no rubies; plates, cocks and bridges are made of stamped metal sheet. The maker of the movement should be the company A. Schild. The escapement is of the pin lever type.
Interesting is the regulator: the form is a sort of shock protection, or at least sold as such; probably the reason for the definition Robust; other writings were shock proof, shock resistant and similar.
Ciao
ig33ku. The two watches above are of interest, though only when they have a movement inside. The first one is a Swiss watch cased in 18K gold and is probably what it´s worth on the market. The one signed WALTHAM is in a Rolled Gold case, not worth much, till you know what's inside, for instance, a RIVERSIDE, then it's big bucks. Please send photographs of the movements.Found some more watches. No idea what they are (unless they are Swatch and Omega LOL).
No idea how to open this sucker it has no hinge on the back cover and I don't want to force it open.ig33ku. The two watches above are of interest, though only when they have a movement inside. The first one is a Swiss watch cased in 18K gold and is probably what it´s worth on the market. The one signed WALTHAM is in a Rolled Gold case, not worth much, till you know what's inside, for instance, a RIVERSIDE, then it's big bucks. Please send photographs of the movements.
Best wishes,
Allan.
