I bought an old French clock a while back and its striking wasn't working. It was an easy fix, the rack had slipped out of position simply because the pin had fallen out and it had moved forward. I put it right, serviced it and ran it for about 3 weeks and all was fine, it didnt put a foot wrong.
Sold it on ebay and it was fine when it arrived and it continued to run happily for a week or 2, and then started to only strike once. I told the customer to send the movement back and I'd take a look (I'm a curiously honourable ebayer lol) and anyway this is the first of my clocks that's ever had a problem (apart from the one lady who didnt know you had to wind it up that is
So it comes back today and its all working fine
I just can't get it to do anything other than strike the right time.
I thought the old original problem might have happened for some reason, but it hasnt. I've taken the rack off and put a little dab of oil on the post in case it was sticking (although no evidence that it was), but just cant see anything wrong with it at all. I've checked the rack for straightness and all fine. The gathering pallet is gathering as it should. The teeth of the rack is lining up perfectly with the rack hook. I thought maybe the hour hand had worked forward and jammed the rack tail but no.
Is there anything you can think of that would make it only strike once? Anything else I can check? I know the 'internal' striking wheels etc are set up correctly, warning pin correctly positioned to the fly, stop pin , pin wheel etc so I can only think it has to be something to do with the 'outside parts' I'm at a loss to be honest
Customer is lovely and I don't want to send it back only for the same thing to happen again.... Any ideas would be great!
PS The camera flash has made it look very scratched/weird, it doesn't look it in real life!
