R. Whiting clock questions and hoping to learn more
Discussion in 'Wood Movement Clocks' started by lxt123, Apr 13, 2017.
  1. lxt123
    lxt123 Registered User
    Apr 13, 2010
    #1 lxt123, Apr 13, 2017
    This is my first wooden movement clock.
    Does it looks all original?
    There are two holes on the top, what am I missing there?
    The dial has two additional holes, visible from the back. Is it a recycled dial?
    I am hoping to learn more about it.
  2. George Nelson
    George Nelson Registered User
    Oct 5, 2007
    884
    Tennessee
    Hi, Lxt123,
    Your Whiting clock is a seeming "marriage" of various parts. I base this on my experience with Whiting woodworks clocks, of which I've owned four over the years. Here are my thoughts.
    Whiting woodworks movements are quite identifiable, in that there is a wooden bridge that secures the escape wheel. Your movement lacks this bridge, leading me to believe that it is not a Whiting movement. It identifies as a type 5.13 made by Chauncey Jerome, if my eyesight serves me. This is assuming that both strike wire pivots are wood, which is difficult for me to see for certain. I am also assuming that the brass bushings around the winding arbors are a later repair.
    Most likely, the entire clock, meaning the columns and splats, were originally stenciled. There are still traces of the stencilling on the columns, but none on the splat, which I'm certain is a modern replacement.
    The face, as you suspect is indeed recycled, as it was originally intended for what is sometimes called an "east west" movement, which had the winding arbors parallel with the hand shaft.
    The top pulley holes and reinforcements are typical Whiting style, so it appears that your case and backboard, left and right top columns are indeed Whiting products. The overall case has, of course, been refinished.
    I'm not trying to be overly critical with my comments, but just want to give you accurate information. Any wood works clock is indeed a great addition to a collection, and perhaps in your travels you will come across a correct Whiting movement to put into the case, along with a good, stencilled splat. Parts like these come up all the time on the Internet auction sites.
    Good hunting, and welcome to the world of wood works collecting!
    My very best,
    George Nelson
    ballistarius likes this.
  3. lxt123
    Apr 13, 2010
    Thank you for the extensive information. Now I have a starting point for my research
  4. Sooth
    Sooth Registered User
    Feb 19, 2005
    3,622
    Cabinetmaker
    Cornwall, Ontario, Canada
    The top splat, and the entire door look like replacements. The door should be pine on the interior, with a dark red stain, and the front should be veneered with mahogany "on the short grain". The door should also be fitted with a Terry style lock (no knob). I don't understand what has been added along the top/rear of the clock. It looks like an old brass handle? There should be nothing there. It looks like someone tried to have this as a wall-hanging clock (which is not a good idea, since the top could separate from the rest of the case, causing everything to come crashing down).
    Most of the rest of the clock looks pretty decent, even if the movement and dial are mismatched marriage pieces.
  5. R. Croswell
    R. Croswell Registered User
    6,642
    23
    Old wooden clocks are often found missing some of their original parts. One has no way to know when this marriage was consummated but perhaps it saved a nice clock from the trash bin. Few people have the means, knowledge, to completely restore a clock like this to all original condition. Be thankful that someone didn't add a quartz movement. You can enjoy your old clock and work toward making it more authentic over time. I would begin by replacing the obviously incorrect hands and movement. Whiting movements come up on-line regularly and are easily recognized by the wooden escape wheel bridge. The two extra holes in the top look like someone decided to add finials and they were either lost or removed (a good thing). Enjoy!
Similar Threads - Whiting clock questions Forum Date
Riley Whiting 3/4 Column and Splat Wood Movement Clocks Mar 30, 2017
Riley Whiting "Winchester" tall case movement Wood Movement Clocks Apr 18, 2016
New Owner of a R Whiting Tall Case Clock - Question about TickTockPro DVD course Wood Movement Clocks Sep 30, 2015
Riley whiting clock in need of parts/repair Wood Movement Clocks Jun 19, 2015
Riley Whiting Clock - wooden movement Wood Movement Clocks Jan 20, 2006
