Quick Question RE: American 30 Hour Movements
Discussion in 'General Questions' started by blindraccoon, Mar 13, 2017.
  1. blindraccoon
    blindraccoon Donor
    Jun 6, 2014
    190
    If such a thing exists, I've never seen it... a Gingerbread/Kitchen mantle clock that has a 30 hour movement with the 'alarm'. Did any of the American clock makers produce this combination?
  2. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    Yes
  3. blindraccoon
    blindraccoon Donor
    Jun 6, 2014
    190
    Thank you for your answer, Tinker Dwight.
    I should have been more explicit. Which American clockmakers or did all of the well known makers produce a 30 hour gingerbread type/kitchen clock with an alarm mechanism?
  4. blindraccoon
    blindraccoon Donor
    Jun 6, 2014
    190
  5. Tinker Dwight
    13,680
    I would think a search would show more. As noted, the 30 hour usually
    have closer winding holes and the 8 day are out near or in the numbers.
    30 hour clocks were usually the cheapest and the alarm was an extra
    cost. I suppose the alarm was offered on all models but not likely used
    on the cheapest models.
    I'd have to go look but I think I've seen the hole in the plate of some
    30 hour clocks for the alarm lever, with no lever attached.
    One might take a look at some front plates.
Similar Threads - Quick Question American Forum Date
Ok quick Question General Questions Dec 6, 2015
A couple of quick and elementary questions...... General Questions Feb 7, 2012
A quick question on late 18th century English Grandfather clock General Questions Dec 6, 2011
quick clock winding question General Questions Apr 9, 2007
quick question General Questions Nov 22, 2006
