Help Question for Seth Thomas Gurus
Discussion in 'Clock Repair' started by lugnutz59, Jan 16, 2020.
  1. lugnutz59
    lugnutz59 Registered User
    Jan 22, 2016
    I am currently working on a Seth Thomas #120 movement that I rebuilt. The Time side runs great, but the Strike side doesn't work. Using Seven Conovers' "Striking Clock Repair Guide", I have narrowed the problem down to the Gathering Pin being out of adjustment. So I pried the Gatering Pin/Pallet off as recommended in the book, and found the position it needs to be in for proper operation.
    Now, my question is how do I press the Pallet back onto the arbor?? It's a fairly snug fit on a small pinion, and I don't want to bend or break anything. Has anyone got any suggestions? I did searh the archives, but didn't find anything there. Any and all help is appreciated! TIA!!
  2. R. Croswell
    R. Croswell Registered User
    9,507
    603
    I have a small metal rod into which I drilled a hole almost as large as the rod. I ground one side flat so I can center the hole in the rod over the arbor even if the pin is close. Then tap the rod with a hammer. At first just set it tight enough not to slip so you can test and adjust if needed. If you put in a bushing on the other plate, put a block of hard wood against the end of that arbor before driving the gathering pallet on or you may lose the bushing on the other plate.
  3. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    6,016
    366
    I acquired an old staking kit years ago at auction. Comes in real handy for setting gathering pallets. It's basically what RC is describing. Using LocTite when placing your bushings comes in handy in these situations too as you shouldn't displace one if you need to set (or pry off) a Gathering Pallet. ;)
  4. Old Rivers
    Old Rivers Registered User
    Oct 4, 2016
    78
    North Texas
    To accomplish this I made a tool out of a 4" long piece of mainspring from a broken kitchen clock. On one end of the spring I cut and filed a narrow 1/2" long vee. The base of the vee is a sharp, acute angle (similar to a crow's foot).
    I place the cut vee so that it straddles the pinion of the arbor opposite the gathering pallet. Then using a hollow punch (carefully relieved on the punch OD so it doesn't touch the pallet's pin) I gently tap the pallet onto the arbor. The axial force of tapping will be borne by the cut mainspring against the arbor shoulder. This has worked well for me.
    Bill
  5. woodlawndon
    woodlawndon Registered User
    Jan 18, 2017
    622
    122
    Woodlawn, Ontario
    This is a good idea Bill, thanks.
    Don
  6. Willie X
    Willie X Registered User
    12,185
    750
    I think this is close to what RC mentioned. It's made from a 3/16" mild steel rod, drilled with a 1/16" center hole. The side slot is made using a .030" cutoff tool. Notice that the slot has to come very close to the hole. This will work on nearly all smalish and medium size clocks. Just one or two very light taps will seat the GP., as already stated.
    Note, I always recommend to remesh the gearing rather than remove a pressed on GP. Willie X
    woodlawndon and Old Rivers like this.
  7. David S
    David S Registered User
    Dec 18, 2011
    7,173
    236
    Brockville, On Canada
    Reading RC's post about problems when driving on the gathering pallet and knocking out a previously replaced bushing, reminded me that on the rare occasion that I have to bush a gathering pallet pivot hole, I do them both with flanged bushings. This way the bush can't come out if the pallet is pried off or driven on.
    David
    Kevin W. likes this.
  8. lugnutz59
    Jan 22, 2016
    Well guys, I took your suggestions, and used a hollow punch to "tap" the pallet back on the Pivot. Worked like a charm. Only have one problem left. The clock strikes right on the hour, but at the half hour, in stead of striking one time, it strikes the same number of times as it did on the hour! I believe I just have a snail adjustment issue, but that's another project!
    Thank you for all the help! Couldn't have done it without your help!
  9. shutterbug
    41,133
    792
    The lift at the half hour should be lower than that at the hour. The bottom tooth on the rack is usually shorter, so at the lift only the short tooth is released, causing a single strike.
  10. lugnutz59
    Jan 22, 2016
    Shutterbug, I see exactly what you are talking about. Possibly I still have to make a pallet adjustment. Back to the drawing board!
    Thanks!
