ATO question about switch contact on ATO
focusrsh_b07732
Dec 17, 2009
79
10
I have what I think is an ATO. I have a question about the switching contact in the "ecapement".
There is an arched arm that rocks. On the end of the arm is a pin that contacts and lifts two brass leaf-springs, In the photo here, the pin is labeled "1". The leaf springs are connected to the -side of the battery through a wire. When the pin touches the springs it briefly completes the circuit to the coil through the clock frame.
However, there is also a brass arm, labeled (2) in the photo, that the springs rest against (or so I think) when they are not lifted. When they touch this arm the circuit is also completed.
OK, so I'm confused. It the pin the switch contact? Or should the pin be coated (insulated) so it is isolated from the brass springs , and thus its only purpose is to lift the two springs aways from the #2 arm and break the circuit.
praezis
Feb 11, 2008
627
103
Germany
Contact is completed by the (platinum-) pin.
Contact leaves and their frame must be isolated from the clock plate.
Frank
whatgoesaround
Jan 22, 2008
595
58
south carolina
The pin should just touch the contacts as it "jumps" out and not rest on them. The lower screws, fourth one up on your picture, will allow for adjustment.
Dave T
Dec 8, 2011
4,593
536
NC
My ONE and only experience on one of these, indicates that the contact should be very light. I adjusted until there was no contact, and then engaged it back just enough!
(For whatever that information is worth.)
focusrsh_b07732
Dec 17, 2009
79
10
I posted the initial question and want to correct something. I said that the brass arm, #2 in the photo. completes the circuit when the flexible contacts touch it. NOT TRUE! It is isolated from clock frame along with the flexible contacts. It has nothing to do with the circuit except to adjust the contact gap.
Latest posts
183,903
1,606,269
55,939
Jerry
3,190
Watch case by Kent
Top Bottom
