They are used for gripping right around the periphery of any disk or ring shaped work-piece.
A conventional 3 jawed chuck will destroy the teeth on a wheel for example if you try to hold it to bore out the centre.
There isn't a lot of gripping surface so using one for something with a lot of overhang isn't a good idea. ( Unless also using the tail-stock).
The distance between steps is the same on all 5 but each starts from a slightly different place. So if you can't find a suitable holding place on the first chuck you work your way through them all until you do.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
