Question about New Haven movement
Rockin Ronnie
Nov 18, 2012
1,737
157
Greenfield, Nova Scotia
antiquevintageclock.com
I might be answering my own question but was there a weight-driven version of this particular movement? I found this in a hall clock. Evidently, someone replaced the movement with a spring-driven one as the chain and weights are still in it to simulate a weight-driven one. The ladder chains are crudely screwed to the backboard. A shame.
Ron
Steven Thornberry
User Administrator
Jan 15, 2004
23,601
1,555
Here and there
I can't recall ever seeing a weight-driven version of this movement, which is often called the square-aperture movement and appears on occasion in Anglo-American clocks.
Reactions: Rockin Ronnie
Jim Hartog
Jan 6, 2010
794
84
Hello Ron,
If this clock originally had a weight-driven movement, there would be a seat board present, or signs of a seat board, or a bracket. A weight-driven movement needs both the rear and front plates supported (cuckoos are an exception?). I have a Gilbert "San Sara" mission floor clock that has a spring-driven movement and fake (empty) weights from the factory (Tran page 355). Maybe someone just added the weights to your clock to make it look like it was weight-driven.
Can you post a picture of the clock so that we can look it up to see if it was supposed to be weight-driven? New Haven did make spring-driven mission floor clocks.
Jim
Jerome collector
Sep 4, 2005
908
105
Omaha, NE
Just to be clear, Rockin Ronnie's and wow's movements are not the same. I took the OP's question to refer to that specific movement (plate design and gear trains). New Haven did make some 8-day movements that could be set up as spring-driven or weight-driven. Like Steven Thornberry, I don't know if that is true of this particular movement. However, in my experience, in the movements that came in both spring-driven and weight-driven variants, the weight-driven ones used cords (not chains) for the weights.
Mike
Rockin Ronnie
Nov 18, 2012
1,737
157
Yes, a seat board makes sense. There is a raised wood platform to accommodate the spring-driven movement. There are 4 screws holding the platform in place. In the next day or so, I will take that out to see if the clock once had a seat board. I only paid $75 for this clock, so, not a great loss if it has been altered. The movement is on a test stand and is running and striking, so, that's a positive!
Jim Hartog
Jan 6, 2010
794
84
Hello Ron,
Your clock does not match anything in Tran Duy Ly's New Haven Clocks and Watches book. The hands are New Haven, the solid brass numerals are New Haven. New Haven did sell mechanical packages to case builders.
And, you're weights look a little small. I have the same New Haven movement that Will has in clocks (non New Haven cases) and the weights are 9" long (without hook), 2" in diameter and each weighs 8 pounds. The ladder chain New Haven used is 40 links per foot.
Jim
Rockin Ronnie
Nov 18, 2012
1,737
157
I removed the raised platform and could not see any evidence of a seat board ever being in this case. I think this is a one-of and not a New Haven factory clock. 72bpm, does that sound right?
Ron
Rockin Ronnie
Nov 18, 2012
1,737
157
A spring-driven New Haven movement, dial, hands, etc. in a one-of hall clock case is a little odd but since I have time on my hands I decided to service the movement and refresh the case with a thorough cleaning, a top coat of Poly-Wipe, and polish the brass. I even kept the fake (empty cans) brass weights for effect. The clock runs well at 72bpm and keeps decent time.
167,147
1,456,514
87,337
Apollodog
