• Upcoming updates
Question about a Waterbury mantle clock.
Chris.K
Jul 15, 2021
318
130
53
I have a fairly uncommon Waterbury that was my Great-Grandmother's and finally have enough experience to feel comfortable to service it.. Now, my question is did Waterbury guild the works of higher end clocks as this one is not the usual oxidized brass ? I do believe this is the mantle version of the Lawrence model but not sure.. Thank you for any input on this.. Chris...
20211031_000600.jpg 20211031_000733.jpg 20211031_000820.jpg 20211031_000924.jpg 20211031_001305.jpg
Andy Dervan
Gibbs Literary Award
NAWCC Star Fellow
Oct 23, 2002
3,002
181
I have never heard or seen any brass clock movements gilded even the high end makers like E. Howard.
It would be very expensive and brass does not oxidize. Clockmakers have been using brass for over 500 years to make movements.
Andy Dervan
Reactions: JTD
Chris.K
Jul 15, 2021
318
130
53
It looks like a perfectly normal brass movement to me, unless I am missing something.
JTD
I misspoke when I said oxidized I meant the normal dirty brass.. This movement is more of a dull gold color. I will post more pics when I get it apart later today..
Levi Hutchins
Oct 21, 2012
138
27
I believe that Waterbury's little novelty clocks, the 30-hour Hornet and 8-day Spider, had gold-plated movements that were displayed through their cylindrical, glass-sleeve cases.
JTD
Sep 27, 2005
10,945
1,542
Difficult to see much detail because of reflections on the transparent casing but I don't see any evidence of gold plating - looks like normal (clean) brass to me.
JTD
Mike Mall
Oct 27, 2021
503
172
Everything (including the movement) looks a lot like an E.N. Welch clock I just got. With a different crown.
Maybe it's a rebranded model?
Edit: I just noticed the post that holds the suspension spring is in a different position. But other than that, very similar.
Probably just a close resemblance.
Levi Hutchins
Oct 21, 2012
138
27
JTD
I was mistaken.
Ken's Clock Clinic that specializes in restoration of these notes "Both the Spider and Wasp were gold-plated with a glass sleeve, and the movement can be seen through the glass.... Most of the internal parts of the movement do not appear to have been gold plated with the exception of the main wheel barrel (due to its massive size)."
In any event, there is no indication that the topic's movement would have been gold-plated.
Chris.K
Jul 15, 2021
318
130
53
It is just a close resemblance as I found my model in a 1890 catalog and it is called the Merwin model and cost $ 8.10 new with the alarm function...
179,055
1,570,539
54,055
Jabberwalky
909
3,088
Swiss Fake by Kent
