Question about 2 Mauthe movements
Discussion in 'General Clock Discussions' started by Rockin Ronnie, Oct 29, 2018.
  1. Rockin Ronnie
    Rockin Ronnie Registered User
    Nov 18, 2012
    1,444
    86
    retired educator
    Greenfield, Nova Scotia
    I have two Mauthe wall clocks that date somewhere between 1900 and about 1910. They are both count wheel strikes. One has the count wheel on the outside of the plates using the usual lifters while the other has the count wheel between the plates with a series of levers much like an American time and strike.
    The horse crown clock is the one with the inside count wheel and levers. Yes, I wondered about the solder job myself. I think someone put on a larger dial or a dial from another clock. Still trying to figure that one out.
    Question. When did Mauthe change their design? And does the design change help when dating a clock?
    Ron
    RS movement servicing (3).jpg RS Horse crown movement (22).jpg RS Finial added (3).jpg RS Mauthe wall clock Oct 27.jpg
  2. Rockin Ronnie
    Nov 18, 2012
    1,444
    86
    retired educator
    Another question. Regarding the first movement. How are the barrels removed and can I remove the striking barrel without taking the countwheel off? The ratchet wheels seem to be very tight.
    Ron
  3. shutterbug
    40,722
    714
    I don't recall that Mauthe movements are designed like that, but it costs nothing to try. Let down the spring, remove the keeper and the ratchet wheel and then see if the arbor will pull out. If not, no harm done. Check the back side for an e-clip too, just in case.
