Query kieninger movement ?
Discussion in 'Clock Repair' started by NEW65, Feb 20, 2019.
  1. NEW65
    NEW65 Registered User
    Nov 17, 2010
    1,063
    26
    Deals in modern reproduction floor clocks.
    United Kingdom
    Hi folks.
    Sometimes due to wear in the centre arbor or chime stop wheel, the 3 x 4 chime fails... on an Hermle movement the chime lift lever (wishbone shaped lever) can be opened slightly to compensate for this wear. However on s kieninger movement it’s not that straightforward because there is no wishbone chime lift lever to open! On this type of movement the chime lift is triangular but solid!
    Can anyone suggest how this type of issue ie failure on the 3 x 4 chime on a kieninger movement be rectified without correcting the wear by rebushing the two worn arbors mentioned above?
    Thank you in advance for any suggestions added.
  2. wow
    wow Registered User
    Jun 24, 2008
    3,766
    211
    Retired Music Minister
    Pineville, La. (central La.)
    Could you post a photo of the problem area? Much easier to give suggestions if we can see the problem.
  3. Willie X
    Willie X Registered User
    12,469
    857
    Slightly bend the tab on the long arm, or the arm itself. Willie X
  4. NEW65
    Nov 17, 2010
    1,063
    26
    United Kingdom
    Thanks Willie, really appreciate the advice. :)
