quail problem
Discussion in 'Clock Repair' started by CJo, Apr 21, 2017.
  1. CJo
    CJo Registered User
    Donor NAWCC Member
    Aug 22, 2005
    347
    Operator in an Ethanol plant. I train new operator
    southwest Kansas.
    I'm working on a cuckoo/quail and somehow or someone, removed the loop on the end of the lift for the quail. Just wondering how would be the best way to repair this. I've thought about it a lot, but would like your input. Thanks![​IMG][​IMG]
  2. shutterbug
    34,335
    29
    If memory serves, that lever should interact with and lift the long loop on the other side. I believe that's what activates the cuckoo after the quail call. You could use a tube to solder on an extension to what you have, or make a new wire.
  3. nsc5
    nsc5 Registered User
    Jan 30, 2017
    There is a video on Youtube of your movement that shows the part, I found it while looking for info on my quail cuckoo: https://www.youtube.com/watch?v=Dhde6rx3F2A As shutterbug suggested the easiest approach is to solder a tube and extension piece in place.
  4. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    One always wonders why people do such things:???:
    "Dang, I hate this wire. I'll snip it off. There, I feel much better."
  5. nsc5
    Jan 30, 2017
    I guess the previous owner really hated the chirping sound from the quail...
    Sometimes things people do defy explanation. I restore a lot of vintage ham radio gear from the 1930s and 1940s and one of the really nice looking radios from that era is the National NC-100X with an art deco silver, black, and red front panel with a green "magic eye" tube. I picked up one for a parts unit because a previous owner not only drilled a hole through the front panel for an added control he chose to drill it right through the styled National diamond logo.
  6. senhalls
    senhalls Registered User
    170
    retired
    western PA.
    The OP is correct . The loop end has been cut . That top lever is not the cuckoo trip lever . The video cited gives the form and length of wire needed . Cuckoo trip lever is further down the wheel train .
  7. THTanner
    THTanner Registered User
    Donor NAWCC Member
    Jul 3, 2016
    961
    Carson City, Nevada
    I have had three cuckoo clocks so far where the owner cut off the tail flip wire "because it was in the way"
  8. Tinker Dwight
    13,680
    That cut one is just for the bellows. The long curved brass lever is pushed down by the pins sticking out
    of the quail's count wheel and is what trips the cuckoo. It is clearly seen in the picture.
Similar Threads - quail problem Forum Date
Quail Cuckoo Help Clock Repair Aug 31, 2017
Quail cuckoo question Clock Repair Apr 30, 2017
Old GHS Cuckoo-Quail Weights Clock Repair Apr 11, 2017
Herr Quail Clock Advice. Clock Repair Feb 7, 2017
Cuckoo/ quail problem Clock Repair Sep 3, 2009
