Proper click spring for Hermle 351-020?
Discussion in 'Clock Repair' started by lmester, Mar 31, 2017.
  1. lmester
    lmester Registered User
    Dec 30, 2009
    442
    I manage HVAC systems for a school district.
    West Virginia
    I think a Timesavers #11617 is the correct one. They don't give all of the dimensions. They just say "Hermle Style Click Spring 1-1/32" Long". I expect that someone on here has replaced many of these and knows if this Timesavers spring fits. Attached are pictures and dimensions.
    View attachment 338584 View attachment 338585
  2. wow
    wow Registered User
    Jun 24, 2008
    2,128
    Retired Music Minister
    Pineville, La. (central La.)
    Luke, I would buy both of the ones offered by Timesavers. They are only $1.00 each. Surely one will work
  3. Jasons34
    Jasons34 Registered User
    Jan 1, 2016
    775
    Millwork
    Pennsylvania
    Yes and you might want to buy a few other things as well. If the total is under like $7 they charge you a fee ontop of that
  4. shutterbug
    34,330
    You mean $20.00, or they add something like a $3.00 processing fee.
  5. lmester
    Dec 30, 2009
    442
    West Virginia
    I should just buy the Hermle click spring assortment plus enough other parts to get above the small order fee. I'm a cheapskate and I rarely work with Hermle movements. Two click springs might be a lifetime supply :)
    I'm a hobbyist. I usually get to pick which clocks I repair. This is what I call a relative repair. A relative called and said "My clock went BOINK and won't wind anymore" Now I'm fiddling around with a Hermle movement:eek:
    You've probably been in this situation. You really don't want to work on this clock, but, don't want to refuse and have unhappy relatives.
    The really unfortunate fact is that there are no longer any professional clock repair shops near me.
  6. Timothy Strano
    Timothy Strano Registered User
    Mar 27, 2010
    29
    Clockmaker
    CT
    I usually just pay the 3 dollar processing fee if I am forced to by from Timesavers. I find 3 bucks is cheaper than spending 20 on stuff I don't need.
  7. Timothy Strano
    Mar 27, 2010
    29
    Clockmaker
    CT
    Imester Give these guys a try http://www.ronellclock.com/
    no minimum order they have what looks like a complete selection of Hermle click springs they always ship the cheapest way.
  8. David S
    David S Registered User
    Donor NAWCC Member
    Dec 18, 2011
    5,791
    20
    Brockville, On Canada
    For all of the reasons mentioned here. I just make my own out of spring steel.
    David
  9. Jim_Miller
    Jim_Miller Registered User
    Mar 6, 2001
    669
    Jackson, Michigan
    David, do you use old mainsprings to make these, or some other source of material?
    Jim
  10. David S
    Donor NAWCC Member
    Dec 18, 2011
    5,791
    20
    Jim, I have used worn out hacksaw or bandsaw blades, as well as steel banding that is used to strap stuff to pallets. I have some 0.015" and 0.020" banding. My local industrial supply shop gives me some stuff that they normally discard.
    David
  11. Jim_Miller
    Mar 6, 2001
    669
    Jackson, Michigan
    I don't have access to the metal strapping, but I do have a few old hacksaw blades. I never thought of recycling them. Great tip, thanks David.
    Jim
  12. lmester
    Dec 30, 2009
    442
    West Virginia
    An update for anyone finding this thread later. I bought the timesavers # 32347 12 piece click spring assortment for hermle. It had the replacement that I needed. I decided that It was worth a few more dollars to just get this clock fixed with a single parts order. Total cost was about $15. And, I now have a supply on hand for the next hermle. I'd thought of making one from a scrap piece of spring steel. Cutting & grinding a tiny piece of spring steel or spend $15?? The $15 option won. If you consider the labor involved, the timesavers assortment is probably the cheaper option.
Similar Threads - Proper click spring Forum Date
Proper pallet pivot peninsula prying procedure. Clock Repair May 17, 2017
proper way to remove spring barrel cap on a Franz Hermle 141-770 movementI Clock Repair Apr 10, 2017
Importance of proper steel to fabricate minute wheel post ? Clock Repair Dec 1, 2016
Proper name of venting on clocks ? Clock Repair Sep 30, 2016
Proper way to rivet click spring Clock Repair Jan 13, 2008
