Production Numbers of Waltham Model 1860 (KW16) with Vibrating Hairspring
Bila
Jan 22, 2010
1,366
467
www.ozwatchstore.com
Does someone happen to know what the total production of the Waltham Model 1860 with vibrating hairspring was?
Ethan Lipsig
NAWCC Gold Member
Jan 8, 2006
2,383
2,130
72
Pasadena
I understand that production of this model was under 100 AWCOs and under 250 Appleton Tracys. I have Appleton Tracy #140,111.
Clint Geller
Gibbs Literary Award
Jul 12, 2002
2,133
1,496
67
Pittsburgh, PA
clintgeller.com
There was one run of a hundred American Watch Co Grade KW16's at SN 125,401 that contained movements with Fogg's stud, but not all one hundred of these movements actually have Fogg's stud. For instance, movement SN 125,412 has a vibrating stud with Fogg's patent marked on the balance cock, whereas movement SN 125,423 does not. Movement SN 125,423 has a Fogg's cam regulator instead, and an appropriate balance cock to go with it. Both balance cocks have assembly numbers underneath matching the ends of their respective movement SNs. It is interesting to note that movement SN 125,423 has a hole drilled in the dial plate at the foot of the balance cock to receive the arbor for a vibrating stud, but the AWCo management apparently changed its mind before the intent was executed. The AWCo Grade KW16 examples with Foggs stud have Breguet overcoil hairsprings and more elaborate exposed stopworks than the AT&Co movements, and the upper pivot hole of the vibrating stud arbor is jewelled, making them 20 jewel watches. I believe all known Fogg's stud movement examples of either the AWCo or the AT&Co grades also have Stratton's patented barrel.
I do not know how many AT&Co grade KW16 movements were equipped with Fogg's stud, but Ethan's estimate seems right.
Reactions: Bila
Ethan Lipsig
NAWCC Gold Member
Jan 8, 2006
2,383
2,130
72
Pasadena
These vibrators are scarce, both in the 20-size and 16-size. I would have preferred to have acquired an AWCO vibrator, but the AT&Co example I acquired had the twin advantages of being available and having a great 18k Browne & Spaulding case.
IMG_2609.JPG IMG_2606.JPG IMG_2610.JPG IMG_2612.JPG IMG_2602.JPG IMG_2604.JPG IMG_2601.JPG IMG_2600.JPG IMG_2598.JPG
164,721
1,433,094
85,764
Stu74111
2,863
