• Upcoming updates
Problem with 1850 French movement
heifetz17
Apr 8, 2015
289
Hey guys, it’s been a while since I’ve posted. I’m currently working on this silk suspension movement and when I have the plates tight the time train stops. If I slacken the plates even ever so slightly it takes off as expected.
Am I missing something with this? There’s almost no clearance between the barrel and first wheel and appears that’s where the binding is occurring.
Is there a spacer of some sort that is perhaps missing?
The strike train runs beautifully.
560A33A6-79BE-4D06-AA33-D2D86D26104D.jpeg EBD647EC-1DDF-4C6E-9422-2AC1775F5E30.jpeg
heifetz17
Apr 8, 2015
289
Never mind, found it! I’m embarrassed that I didn’t notice the strike train spring popped the back of its barrel open when I wound it causing the barrel to twist and somehow place pressure on the time train. All is well again now!
it’s good to be back!
Reactions: shutterbug and wow
180,027
1,570,430
54,350
Davido
911
3,090
