Probable William Leavenworth tall case movement
tbonjour
Oct 27, 2008
57
7
I have what looks to me to be a William Leavenworth wooden tall case movement and dial, except for one feature. It has a vertical slot in the front plate so that the center arbor can be removed without taking the movement apart. This appears to be the same as or similar to what is seen in the Roberts family movements, however I have not seen a reference to Leavenworth using this feature. I know there has been discussion about William Leavenworth movements here in the past and I am wondering if any one here can shed any light on this feature appearing in this movement.
Jim DuBois
James W. Gibbs Literary Award
Jun 14, 2008
4,126
1,727
Magnolia, TX
Tom, some Leavenworth clocks did have the slot for the lift lever to slid out of the plates, see the following
tbonjour
Oct 27, 2008
57
7
Thanks Jim, I will post some pictures soon. The vertical slot surprised me. I had seen references to this being an identifier for the Robert's family movements. I got to ask about the Leavenworth movement in your picture. It is a little unusual! One of his Albany creations I see. My dial is not signed so I assume that my movement was made in Waterbury.
tbonjour
Oct 27, 2008
57
7
Jim DuBois
Jun 14, 2008
4,126
1,727
Magnolia, TX
Yeah, the movement i pictured was special due to its being pretty early as well as having the mickey mouse alarm mechanism. The photo is nearly 50 years old and I didn't recall ever having this clock....I retrieved these photos from an early COG
Peter A. Nunes
Mar 3, 2006
1,720
Rhode Island
www.cogcounters.org
Tom, all (or nearly all) production era tall case movements feature that slot so that the center arbor can be removed without pulling the plates apart. I can't remember ever seeing an exception, and I've seen hundreds of t.c. movements. Really the only distinct feature that makes Roberts family movements easy to spot is the increased distance between the plates.
184,151
1,608,390
56,048
timehousestore
3,196
Joseph Fahys & Co. by Kent
Top Bottom
