Printable Dial For Seth Thomas No. 2 Regulator (Model 61 Movement)
Discussion in 'Case Construction, Repair & Restoration' started by Daryl Watkins, Apr 18, 2020.
  1. Daryl Watkins
    Daryl Watkins Registered User
    Feb 1, 2011
    17
    Is there a printable dial face available for the Seth Thomas No. 2 Regulator?
    Smaller seconds bit for the model 61 movement.
    Roman numeral.
    There don't appear to be many reproduction faces available for this clock, eBay or anywhere.
  2. tracerjack
    tracerjack Registered User
    Jun 6, 2016
    1,067
    111
    Female
    Lodi, CA
    I’m not familiar with the ST#2 other than by name. I assume you are looking for a paper dial? If so, they can be scanned and either the pixels cleaned with a photo editing program, or my preferred way, recreating the dial in a design program. Someone may have already done that for your model, and only need to see your post. I find recreating the dials entertaining, especially the fancy numbers on the older styles, so if your search comes to a dead end, I may be able to help. A quick search on eBay turned up metal dials for ST #2. Were those not what you want?
  3. senhalls
    senhalls Registered User
    285
    20
    retired
    western PA.
  4. Daryl Watkins
    Feb 1, 2011
    17
    Thank you for your reply. I am not an expert on the ST#2 but the particular model movement determines where the holes in the dial are placed. Different models have unique winding arbor and/or seconds arbor hole placement. The model 61 movement that I have is one of the oldest original movements which requires a smaller seconds bit on the face. I am in search of a roman numeral face for this movement. I don't post often but will attempt to attach examples.
    I may have jumped the gun a bit assuming that there is an image file available that I could take to a printer to have a high resolution print made on high quality stock. Certainly if there is a paper dial currently available that would be the route I would like to take.
    After scanning the net for something suitable I came across a website where you can construct your own clock face and print it. Unfortunately I did not see a roman numeral version available. Perhaps a way to import that font might be possible.
    Full Scale Adjustable Printable Clock Face Templates - Metric
    Any help you can offer will be appreciated.
  5. Daryl Watkins
    Feb 1, 2011
    17
  6. tracerjack
    Jun 6, 2016
    1,067
    111
    Female
    Lodi, CA
    The photos are of your dial? I’m a little confused now. Can’t tell from the photo whether the dial is coated paper or painted (screened) metal. It looks to be in excellent condition either way. I could only detect some light smearing of numbers six and seven. Perhaps the photos aren’t showing the true condition.
  7. Daryl Watkins
    Feb 1, 2011
    17
    Sorry, the photos are of a dial that sold on eBay. It is not mine but is the type that I am after. It is considered the "Old style". The seconds arbor is closer to the dial center which requires the seconds legend (bits) to be smaller in diameter. All the others that have been mentioned here are the new type with the seconds arbor spaced a bit further away from the dial center and in turn has a seconds legend (bit) larger than the older one. There are reproductions available but the ones that I see listed on eBay are either the "old" type with Arabic or "new" type with Roman numeral or Arabic. If you examine the two images, there is a larger space between the seconds bit on the old version clock face.
  8. tracerjack
    Jun 6, 2016
    1,067
    111
    Female
    Lodi, CA
    Next question - do you have the dial of your clock so it could be scanned? You didn’t say in your posts if you were looking to improve your dial or were missing it altogether. Either way, the dial could be recreated in a computer design program.
  9. Daryl Watkins
    Feb 1, 2011
    17
    I do not have a dial. To be able to get one created in software would be exceptionally nice. I would have to provide specifications to make sure the end result fits the movement. If there is a person or service that can create an image then I will do my best to get the specs. This will take a little time so if this is doable let me know otherwise I will not pursue.
  10. tracerjack
    Jun 6, 2016
    1,067
    111
    Female
    Lodi, CA
    It’s doable. I’ve done it many times for Sessions, Ansonia, Gilbert, etc, but I have always had the original to scan. I don't know any professionals doing this, although it seems like there should be some. An approximate could be fabricated from the dial photos you posted along with some exact measurements. I find doing them entertaining. While continuing your search for something original, or a professional, if you would like let me play around with creating one, you can start a private conversation with me.
  11. Daryl Watkins
    Feb 1, 2011
    17
    I have PM'd you.
  12. lylepete
    lylepete Registered User
    Feb 9, 2003
    265
    10
    Greenhouse supervisor
    Illinois
    I believe timesavers sell this dial in metal not paper both roman and Arabic numerals.
    William
