Precision micro drill press
Discussion in 'Horological Tools' started by Sanjay Bajpai, Mar 7, 2019.
  1. Sanjay Bajpai
    Sanjay Bajpai Registered User
    Dec 6, 2018
    52
    Retired, hobby clock repairer
    LUcknow , India
    #1 Sanjay Bajpai, Mar 7, 2019
    Made a precision drill press out of a compound microscope stand. Very useful for precision drilling including bushings etc providing clean holes. Can even drill laterally in rods. Good with carbide bits as feed speed can be precisely controlled. General capability is around 2mm in SS and upto 3-4mm in Al without the motor being overloaded with correct feed I.e. Chips from both cutting surfaces
    Regards
    Sanjay Bajpai
    kevin h likes this.
  2. David S
    David S Registered User
    Dec 18, 2011
    7,189
    244
    Brockville, On Canada
    How about some pictures...please.
    David
  3. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    Dear David,
    Did try to embedded a video ex utube. It seems it did not appear in the thread.
    Pics included now please.
    Thought it will help in repair
    Regards
    Sanjay
    20190307_220941.jpg 20190307_220934.jpg 20190307_220922.jpg 20190307_220915.jpg
  4. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    Some add pics please
  5. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,039
    95
    El Dorado, CA
    Nice bit of re-use!
  6. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    Thanks Martin
    But to male it I cut up a new microscope. Fortunately the precision it gives is second to CNC and good for clean vertical holes. If you draw lines by frothing needles n pinch starter points it good enough to maintain gear or wheel axis.
    Has been helpful to me
    Regards
    sanjay
  7. David S
    Dec 18, 2011
    7,189
    244
    Nice going Sanjay, What is the actual drill you are using?
    David
  8. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    Dear David
    Mounted one is 1.4mm cobalt
    Regards
    Sanjay
  9. DeweyC
    DeweyC Registered User
    Feb 5, 2007
    2,053
    714
    Watchmaker
    Baltimore
    THAT is clever! You have a great imagination. The feed on that is terrific. The finish is fantastic.
    What is the smallest you can drill with carbide with that motor/spindle? What motor are you using?
    I suppose someone is going to suggest using a WW headstock or Levin milling spindle; but adding an external motor makes it cumbersome.
    Dewey
  10. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    Dear Dewery,
    Thank you so much. Smallest drill in soft materials is around 0.3 mm that I have tried with very slow feed. You are right a WW headstock of spindle would make it more accurate but I needed a quick workpiece and this felt suitable and compact for small work. Motor is 775 run by a 2A adaptor. Motor is within the AL sleeve which is bolted to the cut microscope tube so for small work its rigid enough. Well that what I thought best.
    Regards
    Sanjay Bajpai
  11. DeweyC
    Feb 5, 2007
    2,053
    714
    Watchmaker
    Baltimore
    30/100mm with carbide? Brilliant. For others, can you specify the motor and where to find it? To be clear, I was not suggesting a WW headstock, I was saying it may well be extra bulk for no reason. Your 30/100 mm sure suggests that is the case.
    I really like it. And a very small footprint to boot. Here goes the price of compound microscope stands!
  12. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    Dear Clark
    Regards
    sB
  13. wefalck
    wefalck Registered User
    Mar 29, 2011
    512
    36
    Geochemist (Consultant)
    Paris
    The precision that can be achieved and the prevention of loss of drill all bears down to the bearings of the motor. I gather your motor has ball-bearings ? The problem with a lot of these motors is also that they are not really made for axial loads, as will occur in a drill. However, it is all a question of what the machine is meant for. There endless ways for sophistication.
  14. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    Dear Wefalck,
    absolutely correct please. I have only tried till 0.2mm and use it for clocks so the precision might be ok. secondly i have installed small thrust bg on the rear of the shaft of motor to avoid axial play. this makes the shaft load the thrust bg rather than th ball bg. well no use beyond this. after this cnc might be the answer
    regards
    sanjay bajpai
    DeweyC likes this.
  15. mossing
    mossing New Member
    Feb 10, 2019
    excellent
  16. kevin h
    kevin h Registered User
    Apr 9, 2015
    408
    151
    cambridge md
    very nice , I was pondering this same problem , once in a while I need to drill a small hole and would love to have that ! What is the actual motor assemble you are using ?
