Hi folks,
I am gradually building up my nerve to take a clock carcass and replace a few pivots with bushings.
One of the things I want to clarify is the role of the 3-point preachers tool for bushing centering.
I understand the role of the two points in establishing an external reference point for the centre of the 'soon to be replaced' pivot. What I'm not sure about is how this benefits you in inserting the bushing into the worn hole. Specifically, if there is a centered hole in the bushing, and it doesn't align with the 3rd point of the Preachers Tool... don't you still have to enlarge the hole to the make it coincident with the 3rd leg of the tool?
If the inserted bushing was actually solid, then the divot made in the bushing could then be drilled and be perfectly centered. But that adds an extra setup step, doesn't it?
I suspect I'm missing the point all together - but thought I'd ask.
Thanks folks,
Doug
Thanks folks,
Doug
