• Upcoming updates
Power frequency monitor clock
Steve Murphy
Jan 8, 2007
142
Sierra Madre, Calif.
This is a power station clock to monitor AC power frequency, similar to the Henry Warren master clocks. Looks like it may be a prototype. The red second hand is driven by the AC clock, the black second hand driven by the mechanical movement. A time switch operates a motor to wind the mechanical movement. The time switch looks like it is made from a self winding f movement frame.
I could not find any information with a google search, the label says D R Clack master clock.
RODALCO
Mar 27, 2006
301
62
New Zealand
That is a very solid, well made movement. Never heard of the maker. Could have been made up by the power companies electrical engineering workshop.
(In the days with local stand alone power generation)
These systems were used as differential clocks, so over a 24 hour period, the power station had "generated" the correct amount of cycles.
50 or 60 x 3600s x 24h.
4,320,000 cycles for a 50 Hertz system.
5,184,000 cycles for a 60 Hertz system.
and keep synchronous clocks showing the correct time. The master clock was kept within very tight tolerances.
Reactions: Steve Murphy
ElectricTime
NAWCC Business
Sep 28, 2002
274
45
It's got a telechron rotor - I wonder if this clock was made by D.R. Clack?
179,055
1,570,547
54,055
Jabberwalky
909
3,088
Swiss Fake by Kent
