Alarm Postman’s Alarm clock
andycole.cole44@gmail.com
Jan 30, 2014
21
Good evening.
I am restoring a postman alarm clock. Purchased with out weights and pendulum. I have located weights. Can anyone help with correct pendulum length and weight etc I will require to get.
Thanks Andy
5,103
638
Good evening.
Thanks Andy
Can you post a picture of the clock? These clocks were made in different sizes and with different movements, so we need to see what you have.
Micam100
Nov 11, 2019
134
27
71
Lusted after one of those fastback commandos when I was younger...still do in fact - and is that a H2 Kawasaki behind it? Sorry can't help you with the clock.
Michael
5,103
638
Hi
Thanks. Hope fully picture attached.
Andy
It looks like this one will have a short pendulum. Can you show a picture of the side of the movement with the door opened? That would confirm my impression. There is a simple way to find the length by testing. Just take a piece of wire, about 15 inches long, of a thickness that fits within the fork of the pendulum crutch. Form a small hook at the top. Hang the wire on the suspension loop on top the back of the movement. Tape something with a weight of about 2 ounces to the wire, about an inch from the bottom. Give your makeshift pendulum a push and let the clock run. If the clock runs fast, lower the weight, if it runs slow, tape it higher. Repeat until timekeeping is almost correct. Measure the distance between the top of the wire and the center of the weight. Add 1 inch. That gives you the ball park of the length of the pendulum you need.
Your clock may have a "pendulum leader", a wire that comes out of the bottom of the clock movement, shaped like a triangle, to which the pendulum needs to be attached. In that case make your wire "pendulum" shorter, about 10 inches long, and hang it to the leader.
Reactions: Tobby
Jan 30, 2014
21
Hi
Thank you very much for the information.
Photos below.
Cheers Andy
5,103
638
The movement is bigger than I originally thought, so the pendulum might be longer, but I'm not sure. It would be best to do the test. The clock does have the pendulum leader. I would start with a 10" wire test pendulum first and see what that gives you. If the clock needs a long pendulum, it would probably be around 60" long.
I had such a clock about 30 years ago but I traded it in and can't remember how long the pendulum was. Maybe somebody here has such a clock and can tell you exactly what you need. Otherwise, do the test. It's fun.
Edit: I just found this thread for a very similar clock. It seems you need the longer pendulum.
Postmans Alarm.
Ned L
Feb 3, 2009
47
27
N.E. CT
Not exactly like your clock, however this pendulum is about 35 inches, that might get you in the ballpark.
166,952
1,454,862
87,200
biggator
