Post Your Waterbury Clocks Here!
Discussion in 'General Clock Discussions' started by Sooth, Jul 8, 2006.
  1. Sooth
    Sooth Registered User
    Feb 19, 2005
    3,899
    51
    Cabinetmaker
    Cornwall, Ontario, Canada
    Since Waterbury is the company I seem to have accumulated the most of, I thought I would start a thread for it. Hopefully no one has already done so.
  2. Sooth
    Feb 19, 2005
    3,899
    51
    Cabinetmaker
    Waterbury 30hr Steeple prior to restoration:
    After:
    http://www.angelfire.com/me5/clockman/steeple1.html
    Waterbury 8 Day Steeple:
    http://www.angelfire.com/me5/clockman/steeple2.html
    Waterbury Ogee:
    http://www.angelfire.com/me5/clockman/ogee.html
    Waterbury Beehive (still awaiting restoration):
    Waterbury 30hr Doric:
    http://www.angelfire.com/me5/clockman/watdoric.html
    All for now. Details on almost all of these are found with the actual clock pages under "Specs".
  3. leeinv66
    leeinv66 Moderator
    Mar 31, 2005
    10,026
    230
    Industry Specialist
    Launceston Tasmania
    This is my Waterbury Cottage clock, It runs for 4 days, but I think the mainspring is to short due to previous repairs.
  4. Sooth
    Feb 19, 2005
    3,899
    51
    Cabinetmaker
    4 Days?
    It looks like a 30 hour, though. Are you sure it might not have some overly strong springs in it? The winding holes close to the centre like that are usually only 30 hr clocks.
    Can you post a photo of the movement?
  5. leeinv66
    leeinv66 Moderator
    Mar 31, 2005
    10,026
    230
    Industry Specialist
    Launceston Tasmania
    Heres the movement Sooth, you could be right, but the spring didn't seem overly long.
    Cheers
    Peter
  6. Sooth
    Feb 19, 2005
    3,899
    51
    Cabinetmaker
    It *IS* a 30 hour. Mine can run a day and a half, but not 4...
    That movement is the same type that's in my "Doric", if you have a look.
  7. leeinv66
    leeinv66 Moderator
    Mar 31, 2005
    10,026
    230
    Industry Specialist
    Launceston Tasmania
    Yep, looks the same to me as well Sooth. I have just wound the clock (3:25pm Sunday here, 16 turns of the key) and will take note of exactly when it stops. Will let you know the result.
    Cheers
    Peter
  8. Chris Radano
    Chris Radano Registered User
    Feb 18, 2004
    3,679
    211
    Pennsylvania
    Here is one for fans of unrestored, 1870's clocks. It is a Waterbury Regulator #2, rosewood veneer case.
    The case needs to be reglued with hide glue. I may buy special precision clamps for the bottom. The loose veneer will be reglued, the chipped areas I plan to fill in with shellac (since, in my opinion, there are not too many chips). Otherwise, looks pretty good. When I find time, for my "day job" has a nasty habit of interfering with fun stuff. Movement is 2 weight, time only, retaining power (the other weight when winding). Interesting open movement plates.
    Here is a question:
    This backing is made of felt. What is a good way to clean this? Thanks.
  9. owen.or
    owen.or Registered User
    Aug 26, 2000
    1,164
    12
    retired high school teacher
    Near Portland, Oregon
    #10 owen.or, Jul 9, 2006
    Waterbury walnut pinwheel jeweler's regulator #7. Sweep second hand. Porcelain dial c.1891.
    David "owen.or"
  10. Sooth
    Feb 19, 2005
    3,899
    51
    Cabinetmaker
    Nice pinwheel, Owen. I love gridiron pendulums. Is it a real one, or just for looks?
    Chris:
    I have two suggestions:
    Felt: Soft bristle brush, and some low tack tape (it's hard to suggest something, not knowing how good the flet is. Is it pretty good, or brittle?)
    Small veneer chips: Fill them with crack filler, let it dry, then with a damp cloth, rub the filler until it's flat and even with the wood. Then simply paint it to match with some acrylic paint, and shellac over it. It will look almost invisible if you get a good colour match.
    For the paints, I always use the same three colours: black, burgundy, and a dark brown. Try it on a small piece of cardboard until you get a close match. Once you get used to mixing the right colour, it's a piece of cake.
  11. dan_46
    dan_46 Guest
    #12 dan_46, Jul 9, 2006
    Heres my oak cased Waterbury Kitchen Clock.
  12. owen.or
    Aug 26, 2000
    1,164
    12
    #13 owen.or, Jul 9, 2006
    Sooth,
    The catalogs I have refer to the mercury pedulum for these clocks as compensating. The Regulator #51 also offered something called a "Compensating Metal Pendulum". Perhaps someone else knows what that is. I do not. There is no reference in any catalog or price guide I have which refers to the gridiron pendulum for this model as compensating. I know there are a couple of other collectors on this board who own one of these clocks. Perhaps they could shed some light. Here is another Waterbury regulator. It is a #67 with two grain painted weights. Time only.
    http://mysite.verizon.net/~davidowen1/DSCN1576wa67.jpg
    David "owen.or"
  13. Chris Radano
    Feb 18, 2004
    3,679
    211
    Pennsylvania
    #14 Chris Radano, Jul 9, 2006
    The felt appears to be sturdy. Thanks. I will try a lint brush first. Was thinking dish soap, and water, then thought maybe not a good idea to get the felt wet. Also, it may turn clumpy when drying.
    That sounds good to fill in the missing chips. Working with wood filler is kind of awkward. What brand do you like?
    I've been meaning to try that faux wood-grained painting...I also have a Welch Verdi-style octagon wall clock. That clock was refinished by someone, who also stripped the wood grained paint. That clock is a dual spring, 8-day, time only movement, probably from the 1870's. Maybe I will post pictures of that one sometime.
  14. Sooth
    Feb 19, 2005
    3,899
    51
    Cabinetmaker
    Hello, Owen.
    Regarding the pendulum, if it just says "Compensating Metal Pendulum" then that would definitely be a gridiron pendulum. The way to check is just to look at it and see if it has 5 or 9 rods, and if they follow an up and down pattern going from:
    steel-brass-steel-brass-steel The rods are always matched in pairs, starting with a steel bar at the centre top, and on the outer bars, and ending in a steel bar going to the rod. And they are riveted or pinned in place to form an up and down pattern from the outside-in.
    I believe the ratios are something like 13 for steel and 18 for the brass. Since the brass expands more than the steel, the compensation works this way:
    +13 (steel down) -18 (brass up) +13 -18 +13 = 0 (or very close to zero)
    That's how they work. Gridiron pendulums were invented by John Harrison in the early 1720's. They work just as good as Mercury pendulums.
    Here's a page showing some plain ones:
    http://physics.kenyon.edu/EarlyApparatus/Thermodynamics...idiron_Pendulum.html
    It's always hard to tell if they are real, especially when they have a fancy lyre decoration over the bottom section like yours. There's also a lor of fake ones that are "just for show". All those do is have 9 rods riveted to two blocks, and they occasionally will have a few bars in the centre.
    Note: gridirons are not always in the "standard" pattern. There is one other configuration that works where the middle rod at the top is the "beginning" and the 3rd and 7th rods both go to the bob (end).
  15. Mike306p/Ansoniaman
    Mike306p/Ansoniaman Registered User
    Jan 12, 2001
    3,024
    Recently retired Police Officer 40 years
    Colorado Springs, CO.
    #16 Mike306p/Ansoniaman, Jul 9, 2006
    Here is my contribution to Waterbury clocks. :)Mike
  16. chrsvor25
    chrsvor25 Registered User
    Jun 16, 2005
    1,243
  17. owen.or
    Aug 26, 2000
    1,164
    12
    Sooth, The "Compensating Metal Pendulum" was one of three options. The others were a compensating mercury pendulum and a gridiron pendulum. The cost for the compensating metal pendulum and gridiron were the same. Doesn't make sense to me that the two would be priced the same if one were compensating and both gridiron. Mine does have nine rods by the way. David "owen.or"
  18. Sooth
    Feb 19, 2005
    3,899
    51
    Cabinetmaker
    The "gridiron" version available might just have been with no decorations. Same idea, but with a different look?
  19. jacks61fd
    jacks61fd Registered User
    Jul 2, 2002
    1,355
    31
    Retired Police officer
    Ocala Florida
    #20 jacks61fd, Jul 9, 2006
    Waterbury "Joliet" cal clock
  20. Chris Radano
    Feb 18, 2004
    3,679
    211
    Pennsylvania
    #21 Chris Radano, Jul 9, 2006
    Here is an American compensating pendulum. From a George Jones "miniature Jeweler's" regulator. Movement with deadbeat escapement.
    Actually, I'm not sure if the movements for these were imported.
  21. Sooth
    Feb 19, 2005
    3,899
    51
    Cabinetmaker
    Well, Chris, having seen that photo, I can say that without seeing the backside, that one is definitely NOT a compensated pendulum. If it were, it would be a terrible one.
    If it's in a basic grid, it would give a total of +23ppm/degree celcius, whereas a sigle brass rod is only +18/degree, and a plain steel rod is +13/degree, it would be basically twice as inaccurate as a plain steel rod.
  22. Chris Radano
    Feb 18, 2004
    3,679
    211
    Pennsylvania
    #23 Chris Radano, Jul 9, 2006
    Oh, well. Hey, we can't win them all. I suppose this one is an American imitation of a real one. Well, I am still going to keep it.
  23. burnz
    burnz Inactive User
    Jan 24, 2006
    1,706
    I do not have pic capabilities at the moment but have one Waterbury clock. It is a brass ship's clock with the 8 bells strike. It is my understanding, that of the companies that made this type clock---Waterbury probably made the fewest.
  24. neighmond
    neighmond Registered User
    Jan 31, 2003
    938
    Horologist, Teacher of Horology
    Rural Iowa
    Here is my old Waterbury:
    http://groups.msn.com/_Secure/0SAAmA*gVoiWb*yB43IsB8WlW5JIEICdwvmL2*Aqqm7OovTcX97CyMEXYozzL47gHlhO1Z0tLXspTojokys2zZXS0v*92Q2gvL3i43!ZCQgBGAAAAynJ9Ag/Whole%20clock.jpg?dc=4675578418830392083
  25. marco5819
    marco5819 Guest
    well here is my 2 cents worth.. A nice waterbury regulator #54 for your viewing enjoyment.. One question tho.. what type of beatscale should this clock have.. paper, or porcelan. and should it have he waterbury name on the scale? View attachment 3083
  26. #27 ClockJim, Jul 14, 2006
    Waterbury "Eaton"
    Waterbury "Viborg"
  27. Ansomnia
    Ansomnia Registered User
    Sep 11, 2005
    2,614
    #28 Ansomnia, Jul 14, 2006
    Waterbury Wanderer
    It's a small 1-day alarm clock, no repeat function that I can discern. I really like its proportions and lines. It needs a bit of attention and I have located the spare parts.
    Michael
  28. Chris
    Chris Registered User
    NAWCC Business
    Nov 4, 2001
    2,470
    Clock and phonograph repair
    Ellsworth, Maine
    #29 Chris, Jul 16, 2006
    Here's my Waterbury china cased clock. The movement was damaged (broken fly shaft.) I got a new gear on a scrap movement from E-bay. The dial is cracked; I have another one coming from E-bay as well. I love E-bay!
  29. Ralph
    Ralph Registered User
    NAWCC Member Sponsor
    Jan 22, 2002
    4,909
    141
    Chris,
    I'd be interested in seeing your George Jones movement. I'm working on one with a one piece dial. The movement is numbered 13 and has a rough mill finish. The pendulum is mounted off the back of the movement. My gut feel is that the movement is domestic and not an import.
    The dial is retained by a soldered in tin pan, that the movement mounts on. The tin pan is soldered to the bezel...
    The pendulum is pretty much like yours . It is numbered 57.
    I'd be interested in a closeup of your top piece and the bottom bracket.
    I could use that incorrect weight from yours.
    Thanks, Ralph
  30. Chris Radano
    Feb 18, 2004
    3,679
    211
    Pennsylvania
    #31 Chris Radano, Jul 19, 2006
    Ralph, You probably mean the weight is incorrect for mine, or do you mean the weight is incorrect for yours? Or, both?
    That is the weight that came with the regulator. Don't know enough about these that I could identify as incorrect. What weight is correct? That one is heavy, comparable to a Gilbert #4 I have. The dial here is celluloid, with a few hairlines. Mvmt. has dead beat escape.
    I can take pictures in a couple days. I have been very busy. This was an acquisition over the winter. It is not running, and needs a service. I have it hanging now because the case has some of the most pleasant proportions of anything I have seen IMHO.
  31. Ralph
    Jan 22, 2002
    4,909
    141
    I'm not sure what weight goes on the GJ's clock, but I would guess it would look Viennese.
    Your's looks like an English regulator weight... and I can always use those.
    The one on this end will be going to the MW regional.
    Is your movement numbered? ...or the pendulum?
    I just put this one on the test stand least night around midnight. It stopped at 3:30 AM.....it looks like a problem in the motion works.
    Hoped to have it ready for the Regional this weekendin Indiana.
    Cheers, Ralph
  32. ClocksCollector
    ClocksCollector Registered User
    Aug 14, 2005
    285
    #33 ClocksCollector, Jul 24, 2006
    My Waterbury parlor clock.
    http://flickr.com/photos/81039818@N00/196467394/in/photostream/
  33. Kevin W.
    Kevin W. Registered User
    22,549
    377
    #34 Kevin W., Dec 9, 2006
    I wanted to post this to a earlier posting this week of a Waterbury kitchen clock.
    However i could not find it.I think thisa modl is later 1890,, or even later.The top was broken off and this piece was added on, i am getting used to it.The movement is not in it as i removed it to overhaul it. :)
  34. Jeff C
    Jeff C Registered User
    NAWCC Business
    May 26, 2005
    2,118
    Seven Fields, Pennsylvania
    #35 Jeff C, Dec 10, 2006
    This is the only Waterbury I have and I'm a little embarrassed that I only know its location history. Its a 30day time only with a seconds hand. I keep it at a restored RR Station. This clock was originally in another RR Station which burn down many years ago, luckily the station was going through a restoration so all the contents were removed prior to the fire.
  35. DBPhelps
    DBPhelps Registered User
    Nov 26, 2002
    383
    Sales Broker
    #36 DBPhelps, Dec 10, 2006
    Waterbury #67 - 8 day weight driven time only movement
    Waterbury ironfront - 30 hr time/strike movement
  36. TEACLOCKS
    TEACLOCKS Registered User
    Mar 22, 2005
    2,350
    77
    Clock service & repair
    Santa Rosa Calif.
    #37 TEACLOCKS, Dec 10, 2006
    My only running Waterbury.
  37. lylepete
    lylepete Registered User
    Feb 9, 2003
    265
    10
    Greenhouse supervisor
    Illinois
    #38 lylepete, Dec 11, 2006
    Here's my only waterbury.
    S_Owsley likes this.
  38. fishpuppies
    fishpuppies Registered User
    Sep 11, 2007
    21
    #39 fishpuppies, Mar 18, 2010
  39. djaninep
    djaninep Registered User
    Jan 5, 2009
    37
    Clinical Social Worker
    Silver Spring, Maryland
    #40 djaninep, Mar 23, 2010
    My two Waterburys. The walnut parlour clock chimes beautifully in my dining room, although it likes to switch back and forth occasionally and chime the hour at the half hour and vice versa. Seems when I wind it after it is almost wound down, it decides it wants to change, then when I would change the hands so it would be chiming correctly, it would play with me and switch back. I have given up, and now I just let it decide how it wants to chime. The Ogee 30 hour keeps great time in my office right next to my computer, but I don't wind the chime side because the original chime rod is too "clangy" for me if that is a word. thanks for looking! Denise 58125.jpg 58127.jpg
  40. MQ32shooter
    MQ32shooter Registered User
    Jul 7, 2008
    863
    13
    Garland, Texas
    #41 MQ32shooter, Mar 23, 2010
    Here's some of my Waterbury wall models.
  41. Kevin W.
    22,549
    377
    Denise thats a awesome Ogee clock, really nice.
    All nice clocks. I have a few more to post here.
  42. Jeremy Woodoff
    Jeremy Woodoff Registered User
    Jun 30, 2002
    4,102
    54
    Brooklyn
    #43 Jeremy Woodoff, Mar 23, 2010
    This Waterbury "Galway" was my first antique clock, purchased when I was age 13. 58158.jpg
  43. Jay
    Jay Registered User
    Dec 12, 2007
    482
    All nice clocks..
  44. Bjorn Toulouse
    Bjorn Toulouse New Member
    Mar 26, 2010
    N.E. oHIo
    #45 Bjorn Toulouse, Mar 26, 2010
    Greetings, all,
    Researching my clock led me to this site, so I guess it's appropriate that my first post is a picture of my Waterbury Regulator #7.
    The clock was purchased by my Great Grandfather from Webb C. Ball Co. of Cleveland, OH in 1911. He had the cabinet made for the clock as it was wall mounted with no cabinet in the Ball Co. shop.
    Rex
  45. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    165
    deceased
    Hi, Rex, welcome to the message board. Nice regulator. Is it a pinwheel or anchor escapement?
  46. Bjorn Toulouse
    Mar 26, 2010
    N.E. oHIo
    #47 Bjorn Toulouse, Mar 26, 2010
    To be honest, Harold, I don't know the difference. That's one of the reasons why I joined this forum! :D
    Here's a picture of the works, taken through the side glass of the cabinet.
    The second pic is one from the web that helped me identify the clock maker.
    The clock has not been tickin' for 20-odd years (it will run for about 10 minutes then stop), and I'm hoping that by digging through the forum I can come up with the info needed to get it back "on the Ball".
    Rex
  47. Steven Thornberry
    Jan 15, 2004
    22,303
    1,113
    Ne’er do well
    Here and there
    The escape wheel has pins; so, it's a pinwheel escapement. Looks like a nice jewelers regulator movement.
  48. harold bain
    40,850
    165
    deceased
    Rex, chances are good your clock just needs cleaning, oiling, and proper setup. It would be well worth having a professional help you with this one. Not a good project for a beginner.
  49. rmarkowitz1_cee4a1
    Nov 26, 2009
    5,263
    906
    #50 rmarkowitz1_cee4a1, Mar 26, 2010
    It's a handsome as well as potentially valuable clock. Pin wheel escapement weight driven regulator (my understanding is all true regulators are timepieces like yours), looks like a porcelain dial, sweep seconds hand, and a nice compensating gridiron pendulum. Super architectural carved case.
    Sounds like a great family history as well.
    Frankly, I agree with Mr. Bain...this is a clock that merits a GOOD professional clock maker. If that person were amenable, they might let you observe/participate in its repair?
    Yes, and welcome to the Message Board.
    RM
