Post your JUNGHANS clocks here
Discussion in 'General Clock Discussions' started by any400day, Dec 2, 2008.
  1. indigoblue
    indigoblue Registered User
    Dec 9, 2009
    11
    Hi I have a Junghens mantle clock that plays the Westminster chimes. It is a large, 18" tall, clock in walnut case with gold face. Has 2 columns on front with brass carving on front the glass is beveled and the works are brass and located in rear. Of course there is all the winding and balancing to make it run. Does anyone out there know of a mantle clock with the same resounding Junghens sound (plus the tick tock). I have never been able to get this clock running always have to call somebody....really tired of it! Thanks DSC03930.JPG
  2. Kevin W.
    Kevin W. Registered User
    21,802
    239
    Indi are you sure it is not Junghans?
    Nice looking clock.Perhaps it would not take much to get it to run reliably.
  3. Steven Thornberry
    Jan 15, 2004
    21,236
    748
    Ne’er do well
    Here and there
    I thought he said it is Junghans.
  4. Jay
    Jay Registered User
    Dec 12, 2007
    482
    Indigo
    I have a Junghans from 1909 that runs very reliably. These were god quality clocks. Perhaps yours needs to be serviced for it to run reliably as well?
    Mine runs daily and keeps excellent time.
    Jay
  5. indigoblue
    Dec 9, 2009
    11
    It is a Junghans but it has to have its pendulum balanced its dials set and wound in 3 places to keep it running. It runs great when I get a clock person to set it up but then when I have to move it around to wind it it just won't do it for me. I really like the sound but hate the clock!
  6. Steven Thornberry
    Jan 15, 2004
    21,236
    748
    Ne’er do well
    Here and there
    I'm not sure what you mean when you say you are moving it around to wind it. Why are you moving it? Moving it with the pendulum attached may throw it out of beat, I suppose, but perhaps you are just not giving the pendulum a proper push to restart it.
  7. indigoblue
    Dec 9, 2009
    11
    Oh no there are little thin strips (slivers) of wood material that under the clock somewhere to balance the works in the back and when it starts to slow down their is a dial on the left of the face in front that you must adjust the dial...(clocks should not slow down they should keep time). Then of course the key was in the storage area in the back where the works are....I took it out so I could just open the front and wind the clock....the front door shuts really tight and so when you open it the clock is jostled and I can hear the little sounds that let me know it was not going to run for me! I did keep it running once but somehow got it off the correct hour and couldn't even fix that it just was chiming and gonging to what ever hour came up and I let it do that until I wound it again and it refused to start again because I tried to get the hour right and wound up moving it from the mantle to the table...wrong move...that was it. The last time it was set about 6 months ago it ran just great though. I even called some local jewelers in the area and none knew how to set it. All the clock dealers/collectors we knew and that came to my dad's antique auctions are all either dead now or not around the area anymore. I even thought of what it would look like to try and find a clock setter to make house calls 2x monthly but I would be really embarrassed to even try to find one.
  8. Jay
    Jay Registered User
    Dec 12, 2007
    482
    Indigo
    Interesting problems?? If you keep the clock wound(all three arbors) it should run fine. As Steven said it is not a good idea to move the clock w/o removing the pendulum. I keep my clock in a set spot and it is never moved; mostly because I lack any place to set it! ha! I rarely,if ever use the slow fast adjustment because if you keep the clock wound regularly(8 days usually or maybe less,if needed) the clock will run fine without the adjustment. You could always wait to set the time at the appropriate hour with a push on the pendulum. I think you might be over thinking the trouble with keeping the clock running? I would say from your description the clock is out of beat and needs to be re-set and perhaps servicing?
    Jay
  9. Kevin W.
    21,802
    239
    Sounds like a mechanical problem and maybe out of beat, as you keep putting slivers under it.
    Your spelling in your posting through me off,Junghens.
    So i was not sure what you had.Thanks for showing it and i hope you get your clock repaired.
  10. livium1966
    livium1966 New Member
    Dec 5, 2009
    engineer
    Suceava, Romania
    Hello,
    I have attached some pictures of my Junghans wall clock. The movement is stamped with a pointed star and inside the star is "UNGHANS" above the letter J. Just below the star is 1214. left upper corner of movement it say "100". Unfortunetely the condition of the clock case is poor and I don't know the original shape. I hope to restore it. Please help me with details about the year of fabrication, or some pictures from catalogue if it is possible.
    Thanks.
  11. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    146
    deceased
    Hi, livium, welcome to the message board. I believe your clock was made in December 1914. It should look good when restored. You may be surprised what a good cleaning will do for it's condition.
  12. celticprince59
    celticprince59 Registered User
    Nov 28, 2007
    403
    Retired. Best job I ever had
    Cape Town South Africa
    Junghans b42
    Hi All,
    I am getting a wee bit confused here with the B42 as being 1924/1942 and after looking and if my memory serves me right I noticed that Vic(apologies before hand if I am wrong) in the thread mentioned a 1907 with a B42 stamp. I was under the impression that the B42 plates were solid and not cut away. Again most likely I am confused. I am attaching some pics of a Junghans that I managed to get hold of this week. The ex-owner said it was a 1936 clock. This movement as can be seen has a count wheel and Junghans moved away from count wheels in the early '20s did they and also it has a coiled gong. I have a feeling that it is a "marriage" of case and movement.
    Need lots of help.
    Andy
  13. harold bain
    40,850
    146
    deceased
    Andy, at some point a few years ago we got confirmation from Junghans that this is a date code on the movements. I posted a Junghans mantel clock a few weeks ago with an A42 movement (solid plates). It does make you wonder how much production there would have been during WW11.
    The unusual clock stamp on the clock before your post, with 12 14 for a date code also makes me wonder about the Junghans date coding.
  14. harold bain
    40,850
    146
    deceased
    Vic is probably right that 42 is really 24. I wonder what his take on 12 14 will be.
  15. celticprince59
    Nov 28, 2007
    403
    Hi Harold,
    I agree with your thoughts as well. If I am not mistaken Junghans retooled to produce for the war effort and I think they only made Luftwaffe clocks alarm clocks timers for munitions. etc
    Maybe Zep can shed some light on the topic.
  16. celticprince59
    Nov 28, 2007
    403
    Hi All,
    Here are some pics after polishing the pivots and wheels and busy planting them
    Hope Vic jumps in and confirms that it is a 1924 Werk 74 movement.
    Andy
  17. scion
    scion New Member
    Dec 12, 2009
    Good evening all,
    I came across this great old Junghans a couple of weeks ago. Just got the back removed showing the 8 sided star with "unghans" above a "J". Isn't running at present. I am a little curious to know what a complete clock might look like. It looks like a brass ring of sorts should be on the base where it meets the pillars. And maybe something similar where the base sets on a table. Hope to get it repaired and running soon. Thanks for any help.
  18. Steven Thornberry
    Jan 15, 2004
    21,236
    748
    Ne’er do well
    Here and there
    Scion: Welcome to the Message Board. An interesting little clock. I can't help with what might be missing, I'm afraid, but I was able to find a relative of your clock on antiqueclockspriceguide.com here.
    There was also a recent thread on a similar style clock by Globe Clock Co., with a movement by Lux. Here.
    Just in case you are interested. I hope someone can come along with some more info.
  19. scion
    scion New Member
    Dec 12, 2009
    Steven, Thanks for your reply. I did see that clock that you mentioned. They actually sent me to your site for help. Both sites now have pics of the clock so maybe somebody somewhere someday might recognize it. I'm not a collector nor do I do any work on the old clocks but I do find the craftsmanship and the uniqueness of them interesting. I work at an antique store and occassionally a clock will come through the door that catches my eye. I really like some of the "everyday" clocks of the Art Deco era. I have to guess my clock pre-dates that era by a little. The clock in my pics was put "on hold" at our store for a customer and as soon as I saw it I told them if this customer backs out I'll take it. I hope to get it working at some point and give it as a gift. Thanks again for your help.
  20. Antti81
    Antti81 Registered User
    Dec 17, 2009
    31
    Finland
    Hello. This is my firts time in this blogs.
    I have junghans wall clock. This is perhaps old? There is mark A11 clock mechanism. Do you have any information clock age? There is some pictures in junghans clock.:)
    T: Antti
  21. Steven Thornberry
    Jan 15, 2004
    21,236
    748
    Ne’er do well
    Here and there
    Antii: Welcome to the Message Board. You have a very nice clock. The A11 on the movement indicates that it was made in the first half of 1911.
  22. Antti81
    Dec 17, 2009
    31
    Finland
    Reply to Steven. Thanks for quick answer. :) I have another Junghans wall clock, but i don`t have pictures yet. I take some pictures and send them just little later.
  23. zepernick
    zepernick Deceased
    Aug 8, 2004
    2,602
    7
    #173 zepernick, Dec 17, 2009
    Scion --
    I've not gone through all of the Junghans catalogues now available on CD, checking for example if there were different names for this beast, or if they had different bases. There was for instance a four-legged variation. It shows up however in a Junghans No. 104 catalogue from 1905 (as below). This CD is at hand as it's the most recent one offered by Vic Tang.
    Zep
    Greetings Andy --
    Below are two views of a 74'er, from the "Junghans, Schramberg Gesamtkatalog, 1911" CD made availabe by the Deutsche Gesellschaft für Chronometrie.
    As to production during the two world wars, I'm fairly positive <G> that most German manufacturers did continue with some "civilian" models, if under (of course) controlled rates.
    I recently wrote about some made during the Great War. The ad below is from 1915. Other clocks made during the war looked "normal" except for e.g. less brass in the movements.
    That said, I'm not aware that anyone has specified how much of what was made when by Junghans in either war.
    Zep
  24. scion
    scion New Member
    Dec 12, 2009
    Thanks Zep. It gets me one step closer to figuring it out. I'm new at this clock researching so I was not aware of Junghans catalogs on CD. Thanks again.
  25. celticprince59
    Nov 28, 2007
    403
    Hi Zep,
    Thanks for the info of course the confusing bit is the B42 but I amalmost certain now that after doing a bit of digging it is a 1924 model Werk74.
    Once again thank you.
    Hope you all have a great Festive Season in case I do not get on before Christmas. The wife has had a hip replacement so I am trying to be housewife and not succeding very well. he he....Housemaid's Knee
    Andy
  26. any400day
    any400day Registered User
    NAWCC Life Member
    Aug 26, 2000
    481
    Singapore
    Harold,
    I am with you on this and also think “.14” stands for 1914. I have seen different movement models with their back plates stamped with A14, 2.14, 3.14, 5.14, 7.14, 8.14, 9.14, 12.14 & 1.15. There were also 1918 & 1919 stampings as shown in the attached pictures.
    Andy,
    Junghans used count wheel strike on their W74 movement till they changed to W202 in 1927-1928. The W202 had both count wheel & rack strike models till at least 1929. I do not have any 1930 & 1931 catalogues with reference to this model. W202A was introduced in 1932 which is only rack strike.
    I am still of the opinion that “A & B 32, 42 & 52” stands for 1923, 1924 & 1925 but have yet to find any concrete evidence to confirm that.
    Vic
  27. any400day
    NAWCC Life Member
    Aug 26, 2000
    481
    Singapore
    Hello Instarclock,
    From the layout of your W74 movement backplate and the flat levers for the strike-works, I would date your clock from 1910 to 1927. While most of their movement would have a “AXX or BXX” date mark for that period, I have seen several with just the Junghans and eight pointed star. I am attaching a picture showing the difference between the Pre 1910 and 1910 and later movements & levers.
    Vic
  28. instarclock
    instarclock Registered User
    Mar 23, 2009
    422
    Galveston
    Thanks for the info Vic! As always, there's a wealth of information to be found here.
    Rt
  29. zepernick
    zepernick Deceased
    Aug 8, 2004
    2,602
    7
    This is now without a doubt the best site (place, source, venue, etc.) internationally for specific information about Junghans clocks. And this is largely a result of Vic's efforts.
  30. harold bain
    40,850
    146
    deceased
    I'll definately second Zep's comments, Vic.
    Just wondering if my mantel clock with a B25 movement throws a monkey wrench into your theory of the reverse numbers such as B52?
  31. any400day
    NAWCC Life Member
    Aug 26, 2000
    481
    Singapore
    Harold,
    I have so far not documented any B52 markings, they are only A/B 32, A/B 42 & A52 so my guess is that they went back to the conventional B25 in the second half of 1925 and continued this way till 1927/1928.
    Vic
  32. harold bain
    40,850
    146
    deceased
    Thanks, Vic, that makes sense.
  33. gtodude2
    gtodude2 Registered User
    Nov 14, 2008
    191
    Full time student studying Funeral Services
    Florida
    Here a Junghans I picked up yesterday. It's in excellent shape and running quite well since the extraction of a piece of cloth from the flywheel. :D Picked it up in a package deal of two clocks. A hundred bucks for the both. The other is a run of the mill Sessions mantle, but I believe I scored with this one. Enjoy!! Almost forgot to add, the stamp under the Junghans star says B.62.
    Eric
  34. Antti81
    Dec 17, 2009
    31
    Finland
    Hello. This is pictures junghans clock that i buy one weeks ago. There is B32 mark in movement. Some kind bird on top of clock, mayby eagle? This clock frame is very good condition.
  35. harold bain
    40,850
    146
    deceased
    Antti, according to our research your clock was made in the second half of 1923. Nice clock.
  36. Antti81
    Dec 17, 2009
    31
    Finland
    OK, thank you for information. If junghans clock had B32 mark in movement it`s 1923 and A52 it´s 1925 year? Mark is opposite in manufactures year?
    Are you sure? :) Sori, my very bad english writing skill.:D
  37. harold bain
    40,850
    146
    deceased
    One of our members, Any 400 Day, has been researching these clocks, and his conclusions are that for a short period of 3 or 4 years, Junghans used a backward code to date their movements.
  38. Antti81
    Dec 17, 2009
    31
    Finland
    Hello. Maybe Any 400 Day is right. I read he´s text and wonder why junghans movement code would be backward ?:)
  39. Paula
    Paula New Member
    Jan 8, 2010
    #189 Paula, Jan 8, 2010
    Hi Everyone!
    I'm sooo pleased to have found this site (through Bing). My DH is the collector--we have 8 clocks of varying sizes and several pocket watches. The newest clock is a Junghans, and I'm trying to find out its particulars for insurance purposes. No, I'm not asking for an appraisal, just an identification. It's a real cutey, small--9" x 7.5" x 4.25". A mantel clock, I'm assuming, in what looks to be a variation of the Mission Style. It's squarish, made of dark oak, with beautiful graining. The flat top has fine beading along the edge, face and sides only. Twisted "ropes" have been embedded in each front corner, and it has little round button feet of oak. The bottom has kind of a ruffled trim. The face is silverish with no markings and Arabic numerals. The trade mark on the back is the middle one (in the post below), the 8-pointed star with the large J and "UNGHANS" above the J. Below the TM is "Wurttemberg" and below that, the numerals "277", no spaces or punctuation marks. On the lower edge are the numerals "200". Any ideas? If necessary, I can try to upload some photos. Thanks very much in advance for any assistance you can offer. And BTW, this is a really neat site, very interesting and informative. I can sense the passion of those who post.
    Paula in Oregon.
  40. Steven Thornberry
    Jan 15, 2004
    21,236
    748
    Ne’er do well
    Here and there
    Paula: Welcome to the message board. We do like to see pictures (we,re quite the horological voyeurs:D). And they help us provide you the best possible information. Best would be pictures of both the case and the movement. Let me know if you need help.
  41. Joseph Superfine
    Joseph Superfine Registered User
    Sep 13, 2009
    207
    Where can I find a dial for this clock?
    coolyus
  42. linol330
    linol330 New Member
    Jan 8, 2010
    Hey!
    I was hoping someone could help me ID this alarm clock and/or give me some more info on it. It was handed down to my mom from her grandmother, and we don't have much information on it. All I do know is that it is a Junghans alarm clock, we think it's early 1910 but we're not sure.
    Anyone who can help?
    Thanks,
    Linda
  43. Paula
    Paula New Member
    Jan 8, 2010
    Re: Junghans clock question
    Hi everyone,
    Here's our cutey. Can anyone identify it? Thanks.
    Paula
  44. Steven Thornberry
    Jan 15, 2004
    21,236
    748
    Ne’er do well
    Here and there
    A nice looking clock Paula. I have put this in the Junghans thread where you originally posted, just to keep the record straight. Now let's see if someone can come along and help you with information.
  45. harold bain
    40,850
    146
    deceased
    Hi, Paula, welcome to the message board. That is a movement style I haven't seen Junghans use, but HAC had a very similar round movement. I would say the date for your movement was July 1927 (perhaps Vic can confirm).
  46. Paula
    Paula New Member
    Jan 8, 2010
    Hi Harold,
    I appreciate the input, but I'm not familiar with HAC. Can you enlighten me? My husband is the collector, but in doing research, I'm beginning to get hooked. Some of the clocks I've seen are gorgeous.
  47. harold bain
    40,850
    146
    deceased
    HAC is the Hamburg American Clock Company, which Junghans bought out ( I don't have the dates handy). The research is half the fun in clock collecting, Paula.
  48. any400day
    NAWCC Life Member
    Aug 26, 2000
    481
    Singapore
    Eric,
    Thanks for the pictures and highlighting the “B.62” marking. This is the type of information I am seeking to either confirm or refute my theory. The fonts of the stamping and the dot between the “B” and “62” are a little different from the ones that I have seen. I also used photo editing software to zoom in on the stampings and the “B” is very different and could possibly be a “3”. For whatever it is worth, I am keeping an open mind and hope more of such stampings would be discovered and posted here for further analysis.
    Paula,
    I cannot find your clock in the 1927 Junghans catalogue or any around that time but the 1927 catalogue list a round movement No. 189 with 8-day rack strike & lantern pinions. Good chance that your clock was made by Junghans in July 1927 like what Harold has said.
    Vic
  49. Paula
    Paula New Member
    Jan 8, 2010
    Thanks, Vic.
    There's also a number 200 stamped at the bottom of the back of the works if that makes sense. Appreciate the help very much.
    Paula
  50. zodaly
    zodaly Registered User
    Jan 11, 2010
    Hi, i recently bought a clock for my dad which is quite unusual and something we have never come across before. It is very small, about 3 inches high, and is a barrel(like a beer barrel) mounted on a wooden base. On the face is an eight pointed star with a J and UNGHANS written inside. Could anyone give me any info about this clock?:)
