Post your JUNGHANS clocks here
tracerjack
Jun 6, 2016
1,395
178
Lodi, CA
.... It has now been running for a few days straight; I just cant seem to figure out why it loses time so fast. ...
Losing time is usually something robbing the power, which is usually dried oil and dirt. Oiling will make it work for awhile, but the dirt is still there and will grind into the metal. It would be best to get the movement cleaned.
Amanda Adolf
New Member
Aug 26, 2018
Welcome to the board.
From what can be seen from your photos, the movements looks very dirty and dry. Some of the pivots appear badly worn. The movement likely needs a proper overhaul for it to work properly. You say it's a Junghans, and it may be, but I see no Junghans marking?
It would have been better to start a new thread in the Clock Repair section, rather than tacking your post onto this thread. Perhaps a moderator will move it for you.
JTD
I'm not sure what kind of clock it is. It seems to be very similar to Junghans styles, but I am not able to locate any markings whatsoever.
JTD
Sep 27, 2005
8,005
584
That's another reason for not posting your enquiry in this thread. I hope a moderator will move it for you soon.
JTD
Dave T
Dec 8, 2011
3,363
139
NC
Took delivery of this old bracket clock I bought six months ago maybe. Getting ready to tear it down. But the first hurdle is acquiring the proper pendulum. I'd like to keep it original as possible. So far, I haven't found a pendulum.
But some questions arise. It's a B13, and as I understand the 140 on the bottom right of the movement indicates pendulum length. But that can't happen in this clock as there is no room for a pendulum that long. The pendulum leader is about 140? Is that where the number comes in?
Here's a couple pictures. Someone has also inscribed "EW1267". Wonder what that is.
The second picture is shown with a Hermle pendulum which is the only one short enough not to drag the bottom of the case, and two others I tried, which are too long.
new2clocks
Apr 25, 2005
2,676
329
Pennsylvania
View attachment 493561 View attachment 493562
Dave,
As you may know, B13 indicates that the clock was made in the second half of the year 1913.
Regards.
Steven Thornberry
User Administrator
Jan 15, 2004
22,746
1,250
Here and there
Consider that the 140, if pendulum length, might be in mm, thus about 5.5". Otherwise, possibly it is BPM.
Dave T
Dec 8, 2011
3,363
139
NC
Thanks guys, I knew about the age, and should have indicated mm in the 140 measurement. But with that, there is not more than 3 3/4" from the bottom of the leader to the bottom of the case. The leader measures close to 140. Maybe that's where the 140 comes in?
tony36crab
Sep 7, 2018
Hi again,
This is not my first Jungians clock, but is my most interesting.
A friend has identified this as a marine lever clock probably made with equipment brought back from the USA, and one of the earliest clocks that they made. It is very similar to Waterbury clocks that I can see on the internet.
The brass has aged well, brass pinions all intact.
Interesting swivel pegs to hold the glass within the bezel.
Hope you like the pictures.
Eric Ritter
Oct 3, 2018
10
Hello everyone. This is my first Junghans clock. I bought it yesterday for $100.00 bucks at a consignment shop in Asheboro N.C. It seems to run pretty good and is keeping good time so far. I have attached several pictures below. Hopefully I have posted enough pictures. So maybe someone can give me a little history. The wood and works seems to be in really good shape. Although the the works need a bit of cleaning. It has a ting tang strike and to be honest. It sounds a weeee bit sick. The rods may need a good cleaning. The only way I can explain it. Is the Ting sounds a bit out of tune with the tang strike. If that makes any sense. I look forward to receiving a little bit of feedback and thoughts from you guys. Thanks in advance.
received_255326178470174.jpeg received_567007587070479.jpeg received_710697555996105.jpeg received_600064063743960.jpeg received_1999367453688917.jpeg received_567007587070479.jpeg received_710697555996105.jpeg received_2175323862795721.jpeg received_600064063743960.jpeg received_1999367453688917.jpeg received_255326178470174.jpeg
Steven Thornberry
User Administrator
Jan 15, 2004
22,746
1,250
Here and there
The numbers "39 9" indicate the movement was made in September 1939. the other numbers:
187 = beats per minute
35 = number of teeth of the escape wheel
83 = the pendulum length in millimeters.
Reactions: Eric Ritter
JTD
Sep 27, 2005
8,005
584
I don't think cleaning the gong rods will make much difference (they look fairly clean to me, anyway). I am a little unsure what you feel is not right with the sound but usually improvements can be made by adjusting the hammers just a little. Make sure that when the have struck the gong rod, each hammer moves back just a little, so that they don't muffle the sound. Also, you can adjust the hammer head itself so that it strikes at a slightly different angle. It is just a matter of trial and error and fiddling with the hammers until you are happy or at least happier.
And bear in mind that some gongs didn't sound all that great when they were new.............although Junghans were generally pretty good in that respect.
It's an attractive clock, with a very pretty case and looks in good condition. As Steven has told you, it was made in the very month and year the war broke out.
JTD
Eric Ritter
Oct 3, 2018
10
Thank you Mr. Steven for the information! I would not have guessed that this ole girl was pushing 80 years old! The case/wood is in such good shape . I figured she was made in the 60s Or later!
JTD, I have an update on the strike rods sounding off. I took the rods out and discovered that a previous owner attempted to repair 3 of the 5 rods. Those 3 rods had new solder and that is what is effecting the sound. Luckly......The rods are screw in type.....So I am thinking I may replace all the rods.
I guess that this clock may have been one of the last clocks made before Junghans retooled for the war effort. That makes it even more special to me!
JTD
Sep 27, 2005
8,005
584
Yes, that would certainly affect the tone of the sound. Replacing the rods would likely be the best route to go.
JTD
Richard Gibbons
Nov 13, 2018
13
66
This Jenghans wall clock has been in my family before I was born 1954 I’d love to find out how old it actually is since I’m the last living member of my family and I never bothered to ask before It’s currently awaiting service Thanks Richie G.
Reactions: Dave T
new2clocks
Apr 25, 2005
2,676
329
Pennsylvania
Richard,
Does your movement have a date code on the back of the movement, such as the date code on Kayge's movement (which is B05)? Based on the picture you provided, I do not see a date code.
The trademark on your movement - "Unghans over a "J" inside an eight pointed star" - was registered in 1890, according to Mikrolisk.de. Junghans started date coding their movements in 1901, as best we know. So it is reasonable to assume your clock was made between 1890 and 1901.
The style of your clock is known as a "free swinger". This style was popular beginning around 1900 or so. Therefore, assuming that your movement has no date code, I would say your clock is circa 1900.
Regards.
JTD
Sep 27, 2005
8,005
584
I just bought a Junghuns clock. It says A31 on the movement does anyone have a range of dates as to when it could of been made?
Welcome to the board, Peter.
Your Junghans clock was made in 1931.
It is interesting that the name of the seller was written on the clock dial as Rabinek Dezsö (rövid ö) and not DEZSÕ (hosszú). Perhaps Junghans' printer could not manage the strange 'foreign' letter Õ!
Rabinek was at the same address in Nagykanizsa for quite a long time, even after the street was renamed Horthy Miklós-ut,, then in 1932 he moved to Erzsébet tér.
If you go to www.holmi.nagykar.hu/irasok/4278/1.html you can read all about the shops in Kazinczy utca and even see an advert from Rabinek and a picture of your exact same clock!!
JTD
Reactions: Peter Sefcsik
John Perrin
Nov 21, 2018
51
New York
This is a friend of mines Junghans. Needs some work but looks nice. A42 110 on back of movement. Early 1924.
Any idea if the 2 brackets coming from the back of the movement to a treaded hole in the chime block is original?
Looking for someone to work on it in the Syracuse, NY area, if you know anyone? It is beyond my abilities for now.
JP
IMG_20190115_150415336_HDR.jpg IMG_20190124_101142394_HDR.jpg IMG_20190126_130622448.jpg
Dave T
Dec 8, 2011
3,363
139
NC
Not exactly what you're talking about with the 2 brackets, but I don't see anything on this clock that's not original.
John Perrin
Nov 21, 2018
51
New York
The 2 brackets show up in the picture of the full clock at the top over the dial. They look like they were added to support the movement in the case. Each bracket is different also, made of 2 1/8" thick strips of metal.
JP
Dave T
Dec 8, 2011
3,363
139
NC
Got it. I was concentrating on the movement itself. Took the liberty to "enhance" the picture to show this a little better. Looks to me like the brackets could be at the front of the case extending up from the dial. And it looks to me like they are added after, to stabilize it, maybe? Not sure why.
Added later......Then again, these are probably your pictures? So, bad assumption on my part.
John Perrin
Nov 21, 2018
51
New York
I took the movement out and the 2 brackets are attached to the 2 corner posts of the movement. Those 2 posts are longer to accommodate the extra nut for each post. This lead me to believe the brackets were supposed to be there. But they just do not look that well made or just an afterthought.
I do not have the clock any more or would send more pics.
JP
Alex M
New Member
Feb 13, 2019
Hi Vic,
Some months ago, I purchased a Junghans W70 grandfather clock but I was not able to find any information regarding the age of this clock. I have been unsuccessful in determining the age of this clock from any detail online such as catalogues. Please refer to the attached photos showing the clock stamping with the letters ‘NAH’ on the brass back plate? This is an unusual stamping and I have noticed this on a number of Australian Junghans clocks for sale, such as ‘NAH’, ‘GAH’ and ‘VAH’. In your post #1, you have also observed unusual stampings such as 'SAH', 'GAA' and 'VAH' stampings. What does the stamping ‘NAH’ mean? What were the ages of the clocks with the stampings that you noted? I was wondering if you could provide me or point me in the right direction regarding information about this clock.
The chime block is stamped HAU 215 indicating this block was manufactured by Hamburg Amerikanische Uhrenfabrik. Does HAU 215 provide a clue as to the age of this clock?
Do you have any information regarding the age of this grandfather clock or anyone worldwide who can provide me info with respect to the age of this clock? The clock face may provide a clue regarding the age of this time piece. Alternatively, does Junghans have catalogues from the 1920’s to 1950’s which may list this clock face style?
I appreciate your help with the above inquiry.
Best Regards,
Aussie Clockmaniac.
View attachment 484243 View attachment 484244 View attachment 484245 View attachment 484246 View attachment 484247 View attachment 484248 View attachment 484249 View attachment 484250
Alex Here I have a similar clock.
Cahilleary
Feb 17, 2019
I'm new to clocks, and you will undoubtedly be hearing from me in the future, bemoaning disasters or asking advice. I have just purchased this bracket clock, which the seller said is a Junghans that belonged to her father, a collector of German clocks. There is no mark on the movement--but I haven't yet removed the face of the clock to see the other side of the movement. The silvered dial is raised and slightly uneven, almost as if it were molded, not cut out of metal, and its numbers are pressed, embossed or stamped--whatever the correct term would be. Does anyone recognize this case and/or movement?
Rockin Ronnie
Nov 18, 2012
1,606
125
Greenfield, Nova Scotia
antiquevintageclock.com
View attachment 518916 View attachment 518917
Nice clock. Curious about the thumbscrews on the bottom since the movement is screwed into the front board. Is there a bottom movement bracket?
Ron
Cahilleary
Feb 17, 2019
Hi, Ronnie, thanks for responding. The mechanism is held in place by a steel bracket. I know there are folks on this forum who have access to the Junghans old catalogues and I'm hoping one of them will be able to help me date this. Assuming it is a Junghans. I tried to remove the face today, but it's screwed on so very tightly I'm doing to have to get a stronger little screwdriver to get the job done.
f.webster
Dec 18, 2009
817
Louisville, KY
Okay...so I pick up this spring driven Janghans at a sale. It doesn't have the usual date marking. Only the trademark. Can anyone give me any information on this beauty?
Traolcoladis
New Member
Mar 1, 2019
Hello Everyone,
I believe that this may be the first confirmed A26 posted on this forum.
As you can see, the old timer is needing some TLC. I bought it from local opportunity shop.
From what I can determine it chimes on the quarter hour. West Minster 4 note straight bar chime.
It had paint splatters on it which I have mostly cleaned up.
I need too do more for it.
Would be interested in more information on this “old timer”
I got in a bit of strife as I am currently unemployed. Just told the Misses....here are the images. Will post more when I get the chance...... if I survive the misses.... lol...
662B089E-7251-4AF0-9114-7C19821B771E.jpeg 196D264A-5A06-4F1B-ACAC-3E9689AC6003.jpeg
new2clocks
Apr 25, 2005
2,676
329
Pennsylvania
Your clock has a Hamburg American ("HAC") movement in a case with a Junghans badge. As such, it was most likely manufactured after 1930, when Junghans purchased HAC.
The other possibility is that the clock is a marriage. I am not suggesting that it is a marriage, but the possibility exists, albeit a slim chance. Pictures of the interior of the clock (backboard, etc.) can confirm whether or not it is a marriage.
It is a very nice clock!
Regards.
Traolcoladis
New Member
Mar 1, 2019
Hello Everyone,
View attachment 520993 View attachment 520999
Here are some additional pictures. It is definitely A26 which from what I have been able to gather from this forum means that it was created in the first half of 1926.
Now I have found that when on a level surface that the clock with stop ticking but when inclined by 15 millimeters on the left side it will tick along happily. I noticed the pendulum arm is slightly bent which I am guessing may be the issue. I am going to try and find the replacement hand parts and winding key for the clock online.
Other advice on cleaning the clock face and or body to restore it would be appreciated.
The chime mechanism appears to stick/stall. Is this also a lubrication issue? I have some super lube machine oil. Which specifies it is designed for clocks. So I think it should be fine. I believe that I only need a drop at particular parts of the clock. Advice on this would also be appreciated.
Additional number stamped on the movement plate is 171. ( behind the pendulum)
DA1EC10D-D6AC-425E-BB0F-2DCA60A902AB.jpeg DEB13667-CA64-4F7E-85E6-793BFB0F3D65.jpeg
woodlawndon
Jan 18, 2017
711
178
Woodlawn, Ontario
View attachment 521298 View attachment 521299
Hi Ttraol, you have a nice clock, looks like a two train chimer, I personally haven't come across one yet. To get it in beat you will have to gently bend the pendulum crutch a bit to the left (the inclined side). You can read about beat setting by searching the forum.
You only want to oil the pivot holes where the pivots protrude, nothing else. Just one drop on each hole. Your clock looks like it could probably benefit from a good cleaning and some new bushings, the bushing holes will become elongated with wear. To do that you'd have to completely disassemble the clock and do much reading on this site before you even attempt it, the springs can be very dangerous.
Try a bit of oil on the pivots first and read up on beat setting and see where you go from there.
Don
new2clocks
Apr 25, 2005
2,676
329
Pennsylvania
Any advice on finding someone to do a maintence check of this clock?
Mike,
The NAWCC has chapters in Canada.
https://nawcc.org/index.php/chapter-information/find-a-chapter-near-you
Click on the Canadian flag to find the chapter nearest to you.
You can contact them and request a reference of a repair person.
We also have quite a few Canadian colleagues who perform repair / maintenance work and who frequent the repair boards. If you post in the clock repair thread, you will get better exposure.
Clock Repair
Regards.
Traolcoladis
New Member
Mar 1, 2019
Don
Thankyou for that, I have been reading up on beat setting. I am going to buy a set of keys for winding the clock. As I will need to buy more than one. Does any one want to buy a spare off me.?
They will be 5 pronged with key hole sizes of 4, 6, 8, 10, 12 mm and 5,7, 9, 11, 13mm.
I also have a wall clock as well. That appear to need a pendulum... will post on that later.
Is there any catalogue from the manufacturer that this mantle clock may appear in?
Isaac
Aug 5, 2013
973
182
Folke
Feb 27, 2019
Your clock was made in 1923 and used an Amerikaner style movement (cut out plates instead of solid plates). The movement looks dirty and worn around the mainspring arbors, so I'd suggest getting it cleaned and rebushed where necessary.
Thank you
4,995
611
Your picture of the movement is upside down, so maybe ClockCollector misread the code. I checked again and it is B32, meaning second half of 1932.
new2clocks
Apr 25, 2005
2,676
329
Pennsylvania
I believe Clock Collector is correct.
As best we know (and for reasons unknown), Junghans reversed their date code protocol for the following date codes:
A32 B32 made in 1923
A42 B42 made in 1924
A52 B52 made in 1925
The A and B protocol remained the same.
Regards.
Traolcoladis
New Member
Mar 1, 2019
Today I took out the main Mechanical body of the clock. It involved me first removing the chime rods.
I was correct in that the pendulum arm was slightly bent, also found that the pendulum slide was also bent as well. It was not as daunting as I first thoughtit might be.
Both have been corrected.
The missing minute hand still had the base part of the hand on the clock so I fashioned a temporary replacement out of a ice cream stick and used strong glue to adhere it to the base of what was left of the minute hand ( and letting it dry before putting back on the clock.
I cleaned the areas that I was able to and now I need to obtain a key for it.
I did not attempt to disassemble the main mechanics.
I did find additional markings which I have included images below.
1926 4 - which corresponds to the A26 being the first half of 1926. The “26” embossed into the timber juabove the 17/231 I am thinking further corroborates the creation of the box as 1926. I am guessing that the 4 indicates that the body was created in April. Does this sound right?
The other stamp. 17/231? I am open to speculation and or firm information on this.
The final stamp I can not make heads or tails of happy to be enlightened here.
I the back right hand corner someone has written 2765. I think this may be the quality check on the clock before sale?
The clock face appears to have been nailed into the front frame of the body at 4 points.
I hope that this information is of help to others.
After examining the inside of the clock body. I have not been able to observe additional markings.
F3B6FBC7-898D-477D-A2D7-C48DB0CD1F68.jpeg 6D7E57D1-A09A-40D2-BA5A-3CF8434E84DD.jpeg 30770A31-9CBC-4F0A-9D93-96C3E12A4A5B.jpeg 7148CFFB-BEFC-4FE6-B911-46C2830199FB.jpeg FC71242B-7360-4EF5-AFF2-D60A35C191A3.jpeg
Topic related ad experiment
