Post Your H. Endler Clocks Here
harold bain
40,853
186
73
Re: Need Help With Regulator Clock?
Popeye, nice regulator. Looks like a two weight Vienna. The bottom looks fine, but the top should have a crest. The bob will be a plain brass bob of about 5 inches in diameter. Timesavers part # 10240 should work if you can't locate an original. They also have Vienna head pieces for your top.
popeye
May 8, 2005
1,458
36
Re: Need Help With Vienna 2 Weight/Regulator Clock?
Thanks for the compliment.
Another question-They put fishing line to hold the weights. What should I replace the nylon filament with?
harold bain
40,853
186
73
Popeye, mine has black nylon fishing line on it (came with it, didn't see any reason to change). Some would use catgut cable on these, but the downside is the way it tends to birdsnest whenever you remove the weights.
Scottie-TX
Apr 6, 2004
936
66
81
Mesquite, TX
Couldn'ta writ it any bedder:
What Rev. BAIN writes;
About five, five and a half inches would look nicer. Gut is fine. I prefer black line with a monofilament.
Looks perhaps like a movement by H. Endler, Freiberg/Silesia - Reg. 1877
Nice find!
popeye
May 8, 2005
1,458
36
Would love to roughly the age and more info. Didn't think that old.
Merritts has a 5 3/4" bob, would that work? Also came with weights, but pretty banged up. One is 2.1 lbs and other is 3.4 Lbs. Looked in Merritts and has 4" x 1 1/2". The size I have is 4" x 2". Would the size make a difference? Also wouldn't the size and weight be the same for this clock-maybe not right weights? If so, which size and weight be appropriate?Thanks for the reply.
I gather $125 was a good price?
harold bain
40,853
186
73
Great price, if it looks half as good in person as the pictures show. Weights are usually the same on both sides. Your movement may need some attention if a previous owner decided to increase the weight rather than fix the problem. Are both shells the same size?
5 3/4 inch bob should look good. these clocks don't normally have a large swing.
Jeremy Woodoff
Jun 30, 2002
4,205
106
Brooklyn
There is a dark, horizontal line on the case back, probably caused by the bob rubbing against the wood. This line would represent the mid-point of the original bob. If you measure from the line to the top of the rating nut assembly, that will give you the radius. Double that for the bob diameter.
Excellent price and really nice clock. I love the side columns!
Jeremy
Scottie-TX
Apr 6, 2004
936
66
81
Mesquite, TX
Well; The Merritts' four by one anda half are two and three quarter pounds. I would certainly think it should be reliable on that. Yes; Both weights should be same size - same weight. Before I spent sixty bucks on weights tho, I'd test and make sure they'd run the clock. My guess is that, clean, lubed, and properly running, that much weight should provide reliable operation with CONSIDERABLE over margin - twenty per- cent or more over.
Five and three quarter bob'll look great. Your dial is seven anda quarter. You'll note many viennas have a bob of similar dia. to dial. That gives the clock great geometric balance.
Age? Late, last quarter, 18s.
Buck anda quarter for that? ANY (every) day of the week. You bett!
Nice bargin bro.
jmclaugh
Jun 1, 2006
5,488
285
Devon
Nice clock Popeye and a very good price. As Scottie says it is by Endler who were based in Freiburg Silesia, that mark was in registered 1877 and I think they went out of business in 1890. The top pediment is obviously missing and it looks like a finial is also missing at the base of the case. The photo below is a similar clock by Endler which may help in identifying the likely pediment.
popeye
May 8, 2005
1,458
36
Woops ordered wrong bob. After looking at picsit looks to be a regulator bob. I orederd 5 1/2" vienna. I just reordered a 6 1/2" regulator bob from Merritts. I gather that would work according to the info of balance to the dial. Does that work? Appreciated, thanks.
PS-also ordered the weight of 3.4 oz. Someone had one on ebay and told me the weight was 1.4kg.
harold bain
40,853
186
73
6 1/2 inch should work OK. 3 pounds 4 oz. MAY be a little heavy. I would have done some experimenting with different weights before deciding what was needed. With the movement in good condition, it may strike too fast with the 3 pound weight. However, try it and see.
popeye
May 8, 2005
1,458
36
He said the diameter on his is 5 3/4". Merritts has 5.5 Inches diameter or 6.5 diameter. Wondering which would look better. Thanks.
Scottie-TX
Apr 6, 2004
936
66
81
Mesquite, TX
Judging from the space remaining below the reg. nut, vertical space for a larger bob should be no problem. Now you do understand that a larger bob will have a higher center of gravity and could speed up the clock requiring lowering the bob. If bob needs lowered beyond range of available regulation - you may need to hunt a longer suspension spring or bottom weight the pendulum.
If regulation is not a problem, then bob dia. is simply a preference. My preference would be the largest dia.
The pinwheel I'm currently working on, I recently found a ten inch bob. If I could find a twelve inch bob, I'd even prefer that!
Scottie-TX
Apr 6, 2004
936
66
81
Mesquite, TX
I'd say JON's bob is five inches. How close'd I come JON?
Here: Here, thanks to eBay.de is very probably a six inch bob and a preview of how yours could look with one.
Scottie-TX
Apr 6, 2004
936
66
81
Mesquite, TX
Gimme yer address there POPS!
I'll send ya a relatively old, steel backed, six inch bob. Leave it as is - lacquered with some age or as I would - strip it and bring it to a mirror finish; Your preference. Your old bob. https://mb.nawcc.org/Click Heremclkwrx@aol.com
http://links.pictures.aol.com/pic/ce60Tm3RNe03ypcMQtil8a8L2YASPF2iX7cXv4xQp5Fd3Ig=_l.jpg and the back:
http://links.pictures.aol.com/pic/ce60Tm3RNe03ypcMQtil8a8L2RHX*nayt*Fzv4xQp5Fd3Ig=_l.jpg
jmclaugh
Jun 1, 2006
5,488
285
Devon
Scottie ya certainly do like big bobs. It is 5.5", so pretty close. The inside dimension of the case and the arc of swing may also play a part in the size of bob that could be fitted.
popeye
May 8, 2005
1,458
36
Scottie-That is very nice of you to offer. I just left my address. My name,besides Pop, is Mark. Let me know if you need anything. Much appreciated and thanks again! There is a Santa Claus. Happy Holidays.
MUN CHOR-WENG
Sep 5, 2000
534
85
I have a single weight Vienna made by the same maker as Popeye's clock.
It has a 5.5-inch pendulum bob.
Mun C.W.
jmclaugh
Jun 1, 2006
5,488
285
Devon
Mun,
Very nice with lovely finials and a sexy case and I do prefer the single weight ones. Is it a 60 seconds dial or 45?
MUN CHOR-WENG
Sep 5, 2000
534
85
jmclaugh said:
Mun,
Jonathan,
It has a 45 seconds subsidiary dial.
Mun C.W.
Scottie-TX
Apr 6, 2004
936
66
81
Mesquite, TX
Yes indeed. VERY nice piece, MUNCH. Single weights my preference.
ACK your PM, there so MARK my word and watch your mailbox!
popeye
May 8, 2005
1,458
36
H. Endler Vienna Clock Pics
Trying as new post. Here are the finished pics minus finished top. Two questions-do the weights look to large? Opinions on top? Appreciated and love the bob.
popeye
May 8, 2005
1,458
36
Re: H. Endler Vienna Clock Pics
trouble
harold bain
40,853
186
73
Popeye, looks great:thumb: I think the weights are maybe a bit too new looking, but quite acceptable. Get yourself some dark walnut stain for that top, and you have a terrific looking clock at a bargain price:clap:
Scottie-TX
Apr 6, 2004
936
66
81
Mesquite, TX
Indeed. I think you did well with the top. It matches very well. Certainly bob looks nice and weights look GREAT. No, they don't look too big. They seem to be in proportion with case dimensions and I prefer the weights polished as you have them. I polish EVERYthing on mine.
Helluva bargin ya got there BRO!
jmclaugh
Jun 1, 2006
5,488
285
Devon
Weights are fine, brass should sparkle. The top will no doubt look fine when stained but finials to match the bottom would have been nice, good job though. :clap:
popeye
May 8, 2005
1,458
36
Before & After Endler Vienna-Many Thanks!
I am attaching some pics of before and after of an aquisition. One of my favorites. It is an Endler Vienna Clock. There were a few prior posts for help in getting this to such nice shape. All the responses and aid helped me get this to become my favorite clock. Two special thanks to someone "donating" a beautiful bob for this piece. My favorite part of clocks. Also a recognition of special talent for getting a replacement top to look like the matching grain. It is a fellow clock class member "fume happy". He brought a Merritt replacment top to look like a top that was part of this piece. Nicely done!!! Again, thank to all!
Kevin W.
23,392
627
64
Re: Before & After Endler Vienna-Many Thanks!
Popeye, i can see why this is your favourite clock.Very good job done on it. And good to know people from this board are helping others.That i like to see.:thumb:
Scottie-TX
Apr 6, 2004
936
66
81
Mesquite, TX
Yeah; Hat's off to th' guy who gets HAPPY on FUMES: Great lookin' bookmatch on top. Rosewood perhaps?
CONGRATS! Looks Great.
fume happy
Mar 31, 2005
1,071
NY
I'm glad to see it matches well!
If anyone is curious, I grain painted the top using Tom Temple's method as published under "keeping time" on the main site.
glad y'all like it :)
~Fumey
jmclaugh
Jun 1, 2006
5,488
285
Devon
~Fumey
Wondered how you do that, excellent job and you get to have a cup of tea too. :clap:
zepernick
Aug 8, 2004
2,602
13
Well done Popeye. What good taste (and spinach) can do!
Zep
Stormy
Jan 22, 2007
149
Visit site
~Fumey
FH
Can you steer me to the article, "on the main site", as I can't find it??:?| I would very much like to read about his method. I can do great woodworking,:thumb: but can't seem to be able to get even close to matching all the different finishes on most of these clocks.:bang::bang: I have several clocks, that need some kind of finish work done on them, including some, with raw, replacement parts, I have had to duplicate, to match the rest of the clock.
Stormy:mysad::mysad:
jmclaugh
Jun 1, 2006
5,488
285
Devon
Stormy,
Yeah it is a little tucked away but here it is Click Here
RTC
May 20, 2007
32
Visit site
vienna reg movement ID
I am adding a few pics this may be a 30 day runner as ran 3 days with only a little bit of weight drop...
the marking looks to say schuts marke
with like HE co or ME co
any help thanks Troy
John Hubby
Senior Administrator Emeritus
NAWCC Star Fellow
NAWCC Life Member
Sep 7, 2000
12,294
249
The Woodlands, TX
Re: veianna reg movement ID
Troy, could you post photos of the complete clock? I'm compiling data for this maker to help support my Gustav Becker research. Can't provide a manufacturing date as yet other than it would have been made before the merger with Becker in June 1899.
Kim St.Dennis Sr.
Mar 20, 2003
467
75
Los Angeles
Re: vienna reg movement ID
The easiest way to tell a 30 day Vienna Style Regulator movement is that it winds counterclockwise. This is because there is an intermediate wheel between the winding ardor and the center wheel arbor. Most 30 day VSR movement has 5 arbors and the 8 day VSR has 4 arbors. Also the weights are twice the size of the normal 80 beat Vienna Style Regulator, say 5 to 6 pounds. It would help to have some pictures of the inside of the movement to help determine the type of movement you have. My guess is you have an 8 day with maintaining power.
Scottie-TX
Apr 6, 2004
936
66
81
Mesquite, TX
Not that you need my affirmation, KST, but indeed - 8 day. Usually monthrunners are a little fatter to accomodate that fifth wheel - for some reason often have an arched top, and the final evidence is lacking pivot as seen in front view. Pivot on right is for motion maint. pawl lever - none on left.
RTC
May 20, 2007
32
Visit site
here is a pick of the clock beidemeir period.thanks Troy
171,040
1,493,328
50,086
Johnfn70
2,967
