Re: Newbie needs help
John - quite an interesting clock for your dating data-base.
The serial number is 128092. It is a standard XC movement with a case where the movement has to be accessed via the front bezel opening. My French isn't very good, but I think it relates to a service recognition award (or perhaps retirement) from Lemaitre-Demeestere & Sons in 1927. I believe they were a textile company and are still in business today.
A few other interesting observations on the clock:
1) It all looked pretty original to me
2) The support bracket which connects to the hairspring has been shortened and does not have a screw terminal to connect the power lead. I have seen this before with XC movements that are housed in cases without back doors. I wonder whether this is to aid removal of the movement from the case ?
3) The shortened bracket makes attaching the battery wire a little more tricky (since this has to be electrically-isolated from the frame. This is achieved by using two shouldered insulating washers. Again, I don't know whether this is original ?
4) The magnet as received was N-S-N which is unusual. This explains why the positive wire is connected to the bracket.
5) The original battery lugs were in place at the base of the case. This allowed me to make a simple battery holder screwed to a bit of plywood. this works really well and prevents any excess wiring interfering with the pendulum swing.
6) The fork is constructed with separate silver & fibre contacts (as opposed to the s-shaped contact arrangement). Both fibre & silver are in excellent condition, so either they have been replaced or the clock has not seen many working years ? the pawls are also in excellent condition.
7) I have attached a picture of the as-delivered movement. Maybe the oily grime has helped preserve the movement in good condition !
8) I have cleaned up the movement and it is now working away nicely.
Peter
