Interesting observation about the impact of battery type on electromagnetic clock regulation.
I think there are 2 possibilities here:
1) The under load voltage supplied by the C & D batteries were slightly different. I have often observed that as the battery drains, the amplitude will reduce and the clock will run fast. Note that the model in question does not have an iso-spring to compensate for the change in battery voltage. The clock has the later cobalt magnet that is prone to lose its strength over time.
2) Steel cased batteries may impact the magnetic field and hence impact time regulation. My personal experience is that I have seen it with the small 1/4 second ATO movements where the battery sits very close to the magnet coil. I once made up a battery holder using a steel box and it played havoc with the regulation ! Of course the ATO magnet is a simple N-S magnet, rather than the S-N-S that you find in most Bulles. That said, the cobalt magnet for the clock in question will probably be a N-S magnet. I say "probably" because sometime 2 separate magnets are fitted, creating a N-S-N field.
With the Bulle clock in question, the coil/magnet assembly is quite high on the pendulum rod. So there is quite a distance from the coil/magnet to the battery which is housed in the base. So I would have thought any impact on battery casing would be a lot less than in the case of ATO clocks Personally I would look closer at Point (1) as a possible explanation, but I'm not sure I could totally rule out Point (2) if the battery voltages under load were identical.
It interesting to note that some of the 1/4 second ATO clocks actually has a small magnets mounted on the case, directly behind the main magnet. This was supposed to allow the user to fine tune the regulation.
Apologies for the over-long and meandering response. Hope it makes sense ?
Peter
Peter
