Hello all. I intermittently post here and read the forum depending on when I have time. I have an interest in mechanical clocks and watches. I own a grandmother clock, a pendulum wall clock, a small travel alarm clock, and three cheap automatic watches. I'm going to pose a question which probably has no right answer and which probably has a thousand opinions. Still, I'm curious to know what you have to say.
I don't work on watches or clocks. But I sometimes have to or want to tinker with them, adjusting the beat or the timing. I own three sub $ 150 Stuhrling Chinese made watches. One is running about 9-10 minutes slow per week. From my reading, I think 4-5 minutes / week or less would be a better number. I COULD send it in for warranty, but that costs me $ 45 including a shipping fee and a handling fee. I'm considering regulating it myself. Just opening the back case and tweaking the rate lever. Not adjusting, nor repairing, since it's new. Only regulating. Having someone other than the factory work on it voids the warranty.
Assuming I decide to do so, the question I have is about the POSITION to regulate it in. I know watches this cheap will run inconsistently depending on position. One might say just do it dial up and be done with it. But, I'm not sure it's that simple. I was thinking and the position that the watch is actually running in varies widely, and is rarely dial up.
For example, as I'm sitting here with my hands on the laptop keyboard, the watch is tilted away from dial up at about a 30 degree angle. If I want to read it, I could put it dial up, or I could put it dial toward my face. I spend much of the day sitting at the computer. If I'm walking, the watch is swinging with my arms through a number of crown down positions. If I'm sleeping on my back with my arms at my sides, it would be crown horizontal and dial outward, or possibly dial up if my hands are flat. If I'm sleeping on one side with my arms crossed to avoid crunching my shoulders, it would be crown up. On the other side, it would be crown down. So, as I said, the watch is rarely actually running dial up.
I have the clock tuner app on my Android tablet and it can apparently read the watch if I use a microphone from ear buds right up against the watch. I don't have a timegrapher device other than the tablet, and am reluctant to spend the $ 150 ish on it.
Also, this is a skeleton watch. I can see the mainspring. The auto wind system generally keeps the spring about 1/2 wound and it doesn't stop over night. The coils are neither all the way inside nor all the way outside.
So, having said all that, I'm thinking perhaps I should regulate the watch in the position it's normally in when I'm at the computer, IE crown right and dial up but tilted about 30 degrees off vertical, and with the spring about half wound. Of course, I have to turn the watch upside down to get the back case off.
Anyway, just wondering what your thoughts are. All help is appreciated.
Ron
Ron
