• The NAWCC Museum and Library & Research Center will reopen starting Wednesday, January 6, 2021 as per Governor Wolf's reopening mandate.
Barr & Poole Poole Clock
glr1109
Jun 2, 2002
1,135
Genoa, NY
I'm working on a "Melrose" model, Poole Clock. Everything has been cleaned and polished. It has an average of 26 swings/impulse. The problem is that it is running too fast(even with the pendulum all the way down). I've not come across this problem before on one of these clocks. Any ideas?
Greg
glr1109
Jun 2, 2002
1,135
Genoa, NY
Greg
Ralph
Jan 22, 2002
5,007
183
Have you changed the suspension spring....if yes, it might be too heavy. You might try a lighter one.
Ralph
glr1109
Jun 2, 2002
1,135
Genoa, NY
It looks like an original spring, but may not be...I'll try and thin the one that's there. Just curious to know if there was something I was or wasn't doing. Will let you know what happens.
My biggest problem with repairing clocks is coming to terms with: just because its there...does not mean that the clock worked correctly or very long, before I got it.
Greg
G
Greg R.
Guest
#1. Before thinning the spring I decided to try a different Suspension sping and pendulum. The clock kept time as it should.
#2. I then thinned orignial sus. spring, and placed the original bob on it...ran fast again.
#3. Tried the same suspension spring with a different bob and so far is running well.
#4. Going to measure the "rods" and "bob" and try to weigh both "bobs"
With the exception of cylinder vs. disk and 1 rod vs. the split rod. I have never heard of different length rods or size pend. bobs. Is anyone aware of this?
Greg
Staff online
162,178
1,408,358
83,922
spreant
2,854
Waltham Watches by Clint Geller
