Poole Clock Wig Wag
rodarte3
Aug 27, 2000
25
Does anybody know the dimensions of the little wig wag device that trips the clock pendulum action? The one on the clock is damaged and reproducing the part will be a lot easier it somebody has a photo or dimensions I can use.
Thank You
rodarte3
Aug 27, 2000
25
Thank You
Ray Fanchamps
Aug 24, 2000
1,718
LLareggub
Here are the dimensions.
Overall length .510"
MaxWidth at Pivot .262"
Width of body .09"
Thickness .015"
Short end edge has 45dgre Cut where it "catches" on the serrated trip arm.
Long end from pivot to tip .345"
Short end Pivot to tip .12"
Pivot .035
http://www.clocknut.com/nawcc/bartoggle.jpg
Ray Fanchamps
Candidate for Director NAWCC 2003.
It's your NAWCC, please vote.
[This message was edited by Ray Fanchamps on January 23, 2003 at 13:15.]
Ray Fanchamps
Aug 24, 2000
1,718
LLareggub
Rodarte3 has indicated it's not the same as I posted. I have included a low resolution image of what he sent to me.
I can forward a higher res image if needed.
If anyone has the dimensions for this toggle or a better image let me or Rodarte3 (John) know.
It does look to me though that this part is salvageable, just wick off all that solder and crisp up the "Vee" edge.
http://www.clocknut.com/nawcc/pooltoggle.jpg
I presume John you understand the "wig-wag" or "toggle" as in "Hipp toggle" named after the designer, is brushed past by the pendulum. When the arc of the pendulum swing is not sufficient for the pendulum to brush past the toggle what happens is the stiff upright on the pendulum (seen just below the toggle in the image) snags in the "Vee" of the toggle. When it snags in the V it starts a series of events that ultimately results in the pendulum getting whacked to increase the arc of swing allowing the pendulum to brush past the toggle again.. Noisy , clumsy clocks.
Ray Fanchamps
[This message was edited by Ray Fanchamps on January 23, 2003 at 23:43.]
rodarte3
Aug 27, 2000
25
Thanks, I didn't know the exact name of the device until now.
The Hipp toggle you see was an empirically engineered device based on the observed operation of the clock. It has been working so far so I may have stumbled onto a device similar to the original. I'll clean it up hopefully it'll be ok. And yes it is a clunky design and my expectations for accurate performance is limited but it is an interesting clock.
Thanks again Ray
Dick Feldman
Sep 1, 2000
2,287
127
Colorado, usa
John,
The material and photos I sent to you are the style toggle shown in Ray's drawing. I think that operation should be the same for both styles. I mailed the article on Poole/Barr clocks and a few more photos of the Barr Clock on a CD yesterday.
Please let us know how you come out.
Dick Feldman
Topic related ad experiment
