Polishing wheels?
Ken M
Feb 28, 2009
937
11
Holiday, FL
How do you polish the wheels, or does the ultrasonic do it all?
Wayne A
Sep 24, 2019
672
107
Ultrasonic will clean um up fairly well and I don't polish them unless they are extra grungy. Always polish the main spring barrel though using wool wheel on dremel with little simichrome.
Ken M
Feb 28, 2009
937
11
Holiday, FL
DeanT
Mar 22, 2009
1,405
279
Australia
I use a thin piece of leather with some polishing compound (autosol etc). One end is anchored in a vice etc and polish between the teeth and the crossings etc.
Reactions: Ken M
turboflyer
Feb 17, 2016
222
39
If it’s a show piece, where things can be seen and everything else is polished I have done it by hand and in a lathe . I have used semi chrome and blue magic with great results . Unless you are going to carefully lacquer or use metal bright the glow is fleeting. Some use Renaissance wax though I have not tried that. Teeth need to be kept clean of the lacquer or metal bright, can’t speak on the wax. That said sometimes I wounded if I am the only one who looks at the wheels.
DeanT
Mar 22, 2009
1,405
279
Australia
its the first place I look as its easy to see how much care the restorer has used.
Reactions: turboflyer
Mike Phelan
Dec 17, 2003
10,060
66
West Yorkshire, England
I've never used an ultrasonic, just three clock brushes.
(a) Stiff brush 1 with liquid Brasso including teeth.
(b) Wash brasso off with IPA or petrol - brush 2.
(c) Brush with chalk - available from most suppliers - brush 3.
Blow chalk dust off - this will keep its polish for years.
Reactions: Ken M
Ingulphus
May 29, 2006
725
Oakland, CA
I use a cleaning solution in my ultrasonic called Polychem Deox-007, which brightens tarnished brass beautifully. I bought it from Timesavers years ago, and still have a little over half a gallon (the ratio is one part cleaner to four parts water). And it's biodegradable. Rinse in hot water and dry with a heat gun or blow dryer, and you'll have much less of an effort to polish.
166,113
1,446,963
86,665
Furgus2021
2,883
