Polishing compounds for steel pallets
Phil G4SPZ
Oct 18, 2018
611
101
68
Bewdley, Worcestershire, UK
I have just replaced a steel strip pallet and saddle on an old Welch movement. Having no diamantine (the traditional polishing compound) I used Peek, a mild metal polish recommended by the Museum where I work as a volunteer. The polishing, hardening and re-polishing processes took a while but the end result is pleasing.
Would diamantine have been any quicker or better? I have access to several other metal polishes, including Autosol and Greygate No 5, so I don’t want to buy other products if they will offer no benefit.
Many thanks! Comments and experiences appreciated.
Phil
46,961
1,996
I use wet/dry emery paper. The fine grit leaves things polished nicely while the heavy grit is good for shaping and removing faults.
disciple_dan
Mar 10, 2016
1,074
88
Plant City
I use an Escapement file to remove wear and then polish it with 1,500, 2,000, 2,500 then 3,000 all in the direction of travel.
Reactions: shutterbug
Schatznut
Sep 26, 2020
386
167
SoCal
I use plain old car polish on a felt buffing wheel in my Dremel tool. It's a very mild abrasive that leaves a high shine.
14,351
1,599
First, you don't need anything special, or expensive.
I use fine abrasive papers (usually 400 to 800 automotive) on a backer, as already mentioned, followed by a quick hit on the ole muslin buff turning at 3450 RPM. The buff is charged with Tripoli.
Altashot
Oct 12, 2017
325
96
45
Sand paper glued on popcycle sticks.
I have various grits.
Sometimes, if there are deep ruts, I start with 320 then work my way up.
I have grits as follows. 320, 400, 600, 1000, 2000, 4000, 6000, 12000.
By the time I’m at 12000, the pallets, or whatever else, are like mirrors.
I find that buffing wheels tend to round edges if you’re not careful.
M.
Phil G4SPZ
Oct 18, 2018
611
101
68
Thanks, all. Never thought about using wet & dry papers. I have a selection of fine grades, so I’ll try that next time to remove the deeper marks prior to polishing.
Cor, 12,000 grade wet & dry paper must be something else! The finest I have is 2,500 grade. Perhaps the finer stuff is akin to what used to be called “crocus paper”.
Phil
167,147
1,456,505
87,334
fredericdb
