Pocket Watch runs fast upright only
Discussion in 'Watch Repair' started by dshumans, May 11, 2017.
  1. dshumans
    dshumans Registered User
    Sep 17, 2009
    336
    A very high quality Audemars Piguet minute repeater keeps very good time dial up and dial down, but gains 30 minutes per day in vertical stem up position. The amplitude is very good and the balance runs true in the round and the flat. Would appreciate any thoughts on possible causes to start checking and options for repair.
  2. karlmansson
    karlmansson Registered User
    Apr 20, 2013
    1,948
    Doctor
    Linköping, Sweden
    How does pendant up compare to the other vertical positions?
  3. gmorse
    gmorse Registered User
    7,196
    22
    Retired from Xerox
    Hi Doug,
    Are the amplitude and the gaining rate the same in all four vertical positions, and are both horizontal positions also the same?
  4. 179
    179 Registered User
    Sep 16, 2008
    320
    If it runs good in dial positions, and things go out the window in pendant positions, the first thing I would look at is poise. Next in line for me would be the curb pins.
  5. NC Plumber
    NC Plumber Registered User
    Jan 15, 2011
    303
    I'd pull the balance wheel out and check it for poise first.
  6. Paul_S
    Paul_S Registered User
    Mar 27, 2015
    154
    Timing machine readings would tell you a lot. 30 minutes a day is huge, so I'd suspect that something is rubbing. Any pics of timing traces you could attach?
    To hazard a wild guess, in that position gravity is probably pulling the balance staff closer to the pallet, so the jewel it is engaging improperly in the fork, or the safety pin is rubbing against the roller. The amplitude thus drops, causing a really fast rate.
  7. RJSoftware
    RJSoftware Registered User
    Apr 15, 2005
    7,668
    11
    Loxahatchee, Florida
    Check if you hear anything rubbing/knocking.
Similar Threads - Pocket Watch runs Forum Date
Swiss PW Can someone Identify this pocket watch? Watch Repair Sep 29, 2017
Swiss PW My Jules Renaud / Audemar pocket watch hand Watch Repair Aug 8, 2017
Waltham Model 1894 Pocket Watch, runs, then stops after running fine for 12-14 hrs Watch Repair Oct 27, 2012
English PW My fathers antique 14k Hamilton pocket watch runs only laying flat How to repair? Watch Repair Jan 14, 2010
Hamilton Pocket watch runs slow Watch Repair Jan 6, 2009
