Hello,
I turn to those more experienced then I once more.
From time to time in the NAWCC publications I see articles regarding pocket watch restoration projects. Regarding such I have a question on techniques with the polishing of screw down gold jewel settings from higher grade movements. I currently own a nice Columbus size 18s, 21j., Time King HC movement which is in need of a good service. The two tone plate has a lot of potential going for it being quite bright once you get past the crude. The gold jewel settings appear tarnished. Is it usual practice to try and polish these raised gold jewel settings up some way? If so whats the method? Do you use a tiny buff? Do you remove each setting with its jewel in order to protect the damaskeening? Do you try and remove the jewel from its setting prior to polishing in order to protect the jewel? Thanks for any assistance.
Robert
Robert
