Pocket watch dismantling
Discussion in 'Watch Repair' started by DrP59, Nov 10, 2018.
  1. DrP59
    DrP59 Registered User
    Jul 12, 2018
    Hi guys, need advice on how to separate these plates, removed screws but is being held together in the centre, can't for the life of me figure how it comes apart. New to watch repair doing as a hobby. Have included photos, as you can see lots of muck and rust.
  2. shutterbug
    40,799
    730
    I'll move this over to watch repair for you ;)
  3. Harvey Mintz
    Harvey Mintz Registered User
    NAWCC Life Member
    Jun 7, 2002
    528
    12
    Software Engineer, retired
    South East Florida
    You need to remove the canon pinion, and on this watch you do that by pushing the center shaft out of it from the front.
    I place the movement dial plate up on a steel block, positioning the winding and setting squares in holes in the block so the don't get damaged. Then I push down on the center shaft with the back of a pair of tweezers. You can also tap it out with a small brass hammer, but pushing is safer. If the parts are rusted together, you may need to use penetrating oil of some kind to loosen them.
    When the center shaft is released from the canon pinion, you simply pull it out from the back.
  4. DrP59
    Jul 12, 2018
    Thanks I'll try that.
