Pocket Barometer
MBRD
Mar 25, 2023
7
61
Hi, I have purchased a Pocket Barometer. Need some info for service and cailbration.
Simon Holt
Mar 21, 2017
1,209
306
Shaftesbury, UK
Watch it for a few days. If the needle goes up and down in line with your local pressure readings (which you can get from the internet) then I'd say no servicing is necessary. If the needle does not move then either the aneroid chamber is perforated or the linkage has seized.
For calibration, there will be a screw somewhere accessible, probably on the rear. If the linkage has seized, the needle won't move when you adjust that screw.
Simon
Tim Orr
NAWCC Star Fellow
Sep 27, 2008
2,106
541
Boulder CO
Good morning, MBRD!
I would add to what Nick and Simon have said that an aneroid barometer should make you acquire the habit of being an "instrument tapper." The motions and forces inside the readout of an aneroid barometer are so tiny that you need to tap the instrument a few times before you read it. Usually, you will find that as you tap, the needle settles down and stops moving around. You may occasionally be surprised to find that the needle jumps quite a bit the first time you tap it. (Being an instrument tapper also is a good idea for many mechanical gauge readouts, like thermometers and hygrometers.)
Also a good idea not to be too dependent on your barometer for accurate comparisons with another source. Barometric pressure varies from place to place. The place where your smart phone gets its pressure reading might be quite different from your "local" reading. I have a local airport with a weather bureau station quite near me, and check readings with them via their website. Rarely do they match my barometer(s) exactly, but I don't assume that my barometers are malfunctioning because of that.
Sorry to see that the thermometer is missing. Note also that you have an altitude track. Surveyors used to use this type of instrument. It would be interesting to see the back and also to learn if the front bezel moves and adjusts the mechanism. In practice, you would adjust the pressure against a reliable standard, like a mercury barometer, then carry it to a new location. The altitude scale could then be used to tell you the difference in altitude at the two locations. But very frequent calibration is important for altitude measurements.
Best regards!
Tim Orr
demoman3955
Apr 9, 2022
626
223
66
I was shocked at how easy it is to test them. The guy that has a shop full of them said to put it in a ziplock bag with as much air as you can, and then apply pressure to the bag and it should cause the needle to move. I tried it on 3 of mine and they all worked. The bad thing is where i live, theres never much change in pressure. Too boring to take up my wall space. lol
novicetimekeeper
Jul 26, 2015
12,625
1,779
Dorset
Your smartphone contains a sensor to provide barometric readings. It is sensitive enough to show the difference in barometric pressure between the top and bottom of a door frame. The resolution is far higher than any analogue barometer, either mercury or aneroid.
I always suggest it to teachers at school when teaching pressure. I use an app called phyphox to access the sensors on the phone.
Tim Orr
NAWCC Star Fellow
Sep 27, 2008
2,106
541
Boulder CO
Thank you, Nick!
I had never heard of "Phyphox"! Now have it installed on my phone. And it's free too!
Plus there are lots of other measurements the amateur scientist can make as well!
Do you know where the Apple iPhone "Weather" app gets its data? My iPhone SE IOS 16.3.1 differs from what Phyphox says.
Thanks again!
Best regards!
Tim
184,167
1,608,536
56,057
LindaH7948
3,197
Joseph Fahys & Co. by Kent
Top Bottom
