Hi everyone,
I have a very large corner grandfather clock made by interclock - it has an urgos movement fitted. Without removing the movement i am finding it difficult to identify the model number of the movement. I have tried to use a mirror but its still proving difficult to identify the letters/numbers on the back plate of the movement! I have done my best but wonder if anyone can help me out here to confirm whether i am correct?
I need a crank key for the movement - the old crank key was either 4mm or 4.5mm but i am not sure which one? Maybe to be safe i should purchase the 4.5mm crank key?
The code on the movement as i read it was: UW353563-01 Weights are on cables and it has westminster chimes only. ( i checked it out on Mark's website but nothing matched)
Any help would be very much appreciated - i am hoping that there is a link between the model of the movement and the size of the crank key?
Thank you as always.
Kind regards,
Simon
Kind regards,
Simon
