Please help to id and dating
marylander
Sep 9, 2008
967
86
Maryland
I just won this movement on eBay. I could not find an exact match back plate from RG. The closest back plate number is plate 1419. But the movement back plate does not have Made in Germany, and two small dots. I hope someone can help to ID and date it. Thank you in advance.
Ming
marylander
Sep 9, 2008
967
86
Maryland
Thank you Erik for the identification and dating. In deed, it is Backplate # 1607. Who is Umpire, a distributor?
Ming
KurtinSA
Nov 24, 2014
6,127
711
San Antonio, TX
More than likely an importer.
Kurt
marylander
Sep 9, 2008
967
86
Maryland
Since there is not much activity here at 400 day clock forum, I am showing a few photos of my Philippe Hauck marriage clock. The length of pallets and acentric has been corrected. It is running now.
Ming
KurtinSA
Nov 24, 2014
6,127
711
San Antonio, TX
Ming -
Very nice! This is the first we're seeing of the whole clock. Now that is something you don't see every day!!
Kurt
Wayne A
Sep 24, 2019
1,085
234
Looks a little tricky to remove/replace that dome. Never seen one.
KurtinSA
Nov 24, 2014
6,127
711
San Antonio, TX
I thought so, too, but then I thought doesn't it just slide straight up? More awkward than usual, but easily doable.
Kurt
Wayne A
Sep 24, 2019
1,085
234
Sure it slides strait up if you have gecko grip fingers. :)
Was thinking having to navigate your hands around the top level.
Wayne
John Hubby
Senior Administrator Emeritus
NAWCC Star Fellow
NAWCC Life Member
Sep 7, 2000
12,299
293
The Woodlands, TX
Ming
Ming and all this is most likely a dealer/distributor/importer, possibly with ties to Hauck as this name doesn't show up on any other maker's database of this period. From mid-1908 to mid-1911 I have over a dozen Hauck clocks documented with this name on the dial.
marylander
Sep 9, 2008
967
86
Maryland
John, Thank you very much for your help. It is good to hear from you as always. We hope we can see your book publication soon.
Ming
marylander
Sep 9, 2008
967
86
Maryland
This Hauck has a GB pendulum
Yes, I used a made over base and GB pendulum because I did not have a correct base and pendulum. I only purchased the Ph. Hauck movement. At this point, I only want the clock to work. And it runs very well and keep excellent time using 0.004” S.S. and GB pendulum. Of course, I had to adjust the S.S. length to bring it to time range. Ph. Hauck made very good clock movement. I am very happy with the movement, even the pallet length and eccentric needed to be corrected.
Ming
KurtinSA
Nov 24, 2014
6,127
711
San Antonio, TX
Ah, I see that the pendulum adjustment weights are all the way in. This suggests that the suspension spring should be thicker than 0.004". Unfortunately, the next size up is 0.0045" so some sanding would have been required.
Kurt
marylander
Sep 9, 2008
967
86
Maryland
I appreciate all like the pendulum. I hope the marble disk will not change diameter when room temperature changes. today, the room temperature changed 2 degree F, the time keeping did not have noticeable change.
Ming
Latest posts
Staff online
183,900
1,606,222
55,937
Rwhb12
3,190
Watch case by Kent
Top Bottom
