Please help . I have a Ansonia clock with number 5 on on mechanism, missing a pendulum. Does anyone know what length and weight does in need to be. M
Alex Orlov
Nov 14, 2021
39
Jim Hartog
Jan 6, 2010
1,014
183
Hello Alex,
For Ansonia, the 5 refers to the "drop" of the pendulum. Drop is defined as the distance from the hand arbor to the rating nut of the pendulum. It is not the length of the pendulum. Timesavers sells a 3 1/2" (19369) and a 5 1/8" (19370) pendulum. Likely one of those two.
Your photo does not show the suspension post or suspension spring. If your suspension spring is missing, you have more to do.
It is likely some different opinions will appear here re the 5. I stand by drop, not length for Ansonia.
Jim
Alex Orlov
Nov 14, 2021
39
Hello Alex,
Jim
Thank you so much Jim , I have the hook. I'll try to post a pic . I'm not a clock mechanic or anything, just got this clock with house I bought. Trying to make it work.
Fitzclan
Jul 20, 2014
775
71
Long Island, New York
I had the same problem Kevin. I thought it was the Ipad acting up.
Jim Hartog
Jan 6, 2010
1,014
183
Hello Alex.
It looks like the crutch rod is bent out of shape. That is why the suspension spring is bent. You will have to learn how to "set the beat" on this clock once you have the crutch rod somewhere close to vertical and have a pendulum. Very likely, it needs to be serviced (clean and lube job) so don't expect it to run just because you put a pendulum on. The time side mainspring is wound up tight. Not a good omen.
You didn't ask but your Ansonia is the "Bristol Extra" model. It has the triangle piece on the top which the regular "Bristol" doesn't. You have the visible escapement which was an option back in the day. Your clock appeared in an Ansonia catalogue in 1904 with a price of $13.75 which included the visible escapement. Google Images will show you other examples of your clock.
Jim
49,952
3,168
We had some issues over the weekend with slow load times for large pictures. I tried to modify the first post in this thread so it loads as a thumbnail instead of a full size pic, and inadvertently removed the words too. I'm not sure how that happened. But the second post explains what is needed for those curious about the first one. Sorry!
:rolleyes:
Alex Orlov
Nov 14, 2021
39
Hello Alex.
Jim
Well my understanding that it's tot rare or expensive. Not collectible peace..... Right ?
Jim Hartog
Jan 6, 2010
1,014
183
Hello Alex,
I like cast iron case clocks with open escapements, but I do my own work so I don't have to pay for restoration. Take the clock to your local clock person (hopefully a free estimate) and get an opinion on service cost and value. Even your case is rough. To get your clock into the condition of the one in the link I posted, will take a bit of work. If the cost of service is prohibitive, you may consider just passing it on to a clock person.
Jim
Top Bottom
