The Schatz Miniature 53 which I am repairing has a plastic dome, the original glass dome having been broken nearly 50 years ago. However the diameter of the dome it now has is a little on the large side with the result that it does not fit in the groove properly. If you position one side nicely in the groove, the other side rests on the outer rim of the groove. I was wondering if it were possible to shrink the base of the dome a little by, for instance, placing a large hose clamp (suitably padded) around the base and heating the bottom of the dome with hot water and then tightening the hose clamp a little and allowing the whole lot to cool down. One can do that with modern plastics but I don't know about plastics made in the 1960's. Any comments?
