I've run into something that has me bamboozled. I have overhauled the Ingraham movement from a gingerbread clock. Everything went well. Bushings were installed in the time and strike trains. Upon reassembly, the time train ran great but the gathering pallets were missing the count wheel. I thought the problem was too much back and forth play on the wheel with the gathering pallets. Based on an earlier post, I tore the movement down again to put a shim on the opposite pivot to keep the shaft from backing away from the count wheel. This is something I have never had to do before.
In this process, I discovered that the movement was binding over the second wheel. I can assemble the plates with any combination of wheels and the movement is very free with the exception of the wheel in question - the first wheel in the strike train after the spring. With just this wheel installed, the plates have to be forced together which binds this wheel. I am guessing that the flex in the plates is what is causing the gathering pallets to miss the count wheel.
I did not put bushings into either side of this wheel and this is something that I have not seen before.
The movement is stamped 11 22. The clock would not run at all before repair. I did not verify whether or not the strike train was running before taking the clock apart. The time train now runs perfectly even without lubrication. Lesson #1
Does anyone have any idea what is going on?
A video clip of the problem is here: Ingraham 11-22 1st Wheel.mov
Any and all feedback is appreciated.
