Pivot repair
term789
Oct 19, 2016
37
Could anyone replace this pivot for me?
It's out of a french crystal regulator.
It is a small pivot and don't want to risk doing it for the first time on my lathe.
The pivot is .56mm / .022 inches in diameter.
Jerry Kieffer
May 31, 2005
2,925
546
wisconsin
View attachment 410904 View attachment 410905
If you have the desire to do it yourself, there is little to lose and everything to gain with capable equipment and sound procedure.
Is the pinion hard and what type of Lathe do you have ?
Jerry Kieffer
David 62
Nov 28, 2004
394
I was able to re-pivot a arbor after asking questions here.If you have a lathe,order what you need and practice before you work on the piece that you posted.
lpbp
NAWCC Star Fellow
NAWCC Life Member
Aug 25, 2000
2,968
62
[QUOTE="
Is the pinion hard
Jerry Kieffer[/QUOTE]
If it's French, it's hard.
P.Hageman
Jul 20, 2014
1,115
223
The Netherlands
Just as Jerry already said, its not that difficult if you have a small lathe and a torch. But I can imagine, first time I replaced a pinion on a french clock I was afraid too :D
shimmystep
Mar 5, 2012
4,105
82
Cambridge, UK
If you do anneal the pinion, to re-pivot, you'll need to ensure it's hardened and tempered again.
R&A
Oct 21, 2008
4,203
107
I can do this Send me a message
46,175
1,773
The pivot drills (blade type, sold by most suppliers) will drill through hard steel pretty easily. No urgent need to anneal first, as long as you can file the end flat to start with.
164,878
1,434,708
85,845
le5100kw
2,872
