In your experience:
There are some widely varying opinions here, on when a bushing needs to be installed, for a proper repair.
I have seen the opinion that if one hole is worn, they should all be bushed, because they all wear at the same rate.
I have also seen the opinion that if it's worn with less than 30% slop, that's OK.
In my experience, I have seen pivot holes worn into an obvious oval, while others have play but the hole appears to be completely round.
It's true that the force applied to a pivot is usually from one direction, as it transfers the power through the train.
Obviously nobody takes a movement apart until it's old, and has problems.
So how do we know if a pivot hole was designed, and manufactured a little sloppy?
When pivot holes wear - how often do they wear and remain round?
Is it possible to measure pivot holes for "out of round?"
