Pinwheel
Vernon
Dec 9, 2006
837
90
Found this on a popular website a few years ago. Dad and I made the trip from Ohio to Chicago to pick it up and spending time with Dad was the best part of the purchase. We talked the whole way and discovered restaurants and rediscovered each other along the way. I contacted the person after the auction to set a time and date and we hit it off over the phone as he was a member so we had plenty to talk about. We stayed overnight at the wonderful Carlton Hotel.The next morning we went to pick up the clock and had a very nice experience with the couple. We spent about 3 hours looking over their collection, repair area and having wine. It was tough to leave as we felt like family.
The pendulum hangs from the back of the case and the dial is 9 1/2" less the bezel. Also, the case has a hole in the bottom that allows the weight to drop through. The hole appears to be missing a glass panel perhaps as I see evidence of nails to hold glass in place. This clock runs 8 days before the weight reaches the whole at the bottom. Does anyone know about such a clock with these features?
Vernon
Dec 9, 2006
837
90
jkfabulos
Aug 21, 2001
944
78
I suspect the bottom hole had a mirror which would reflect the pendulum since as you have noted it runs eight days without needing the weight to fall through.
Unusual mounting bracket with pendulum suspended from it rather than the typical front mount pendulum hanging from a suspension spring and leader attached at the front of
the iron box frame the movement is mounted to.
Case with double glass sides where most of these had just one long piece of glass at the sides.
Case most likely had some type of top and bottom. Are there any holes or shadows that would give you a clue as to if this is likely?
Vernon
Dec 9, 2006
837
90
No shadows or other evidence. The plainness attracted me as some cases can be very elaborate. The seller said that a friend brought it back from Austria as I recall. DSCN1912.jpg
jmclaugh
Jun 1, 2006
5,077
191
Devon
Sounds like a nice road trip and a lovely clock with such a big temperature compensating pendulum and driven by such a small weight. I've never seen a wall clock with a cut out hole in the bottom of the case but glass does seem the obvious answer as to what was there for though with a long enough line it would run for much longer!
Topic related ad experiment
160,891
1,395,868
82,895
MDHusker
1,099
2,787
Last category
Pocket Watches by Clint Geller
