Hello there. I just got this jewellers regulator and I have started to service it but having some questions. Always impressed with the knowledge and helpfulness of you people. I've checked out all the older threads and got some great information, but still some problems. First, movement mechanics match what I see described as a French made pinwheel except my end plates are not brass, rather nickel I believe. Also suspension spring holder block mounts above steel cage. Can anyone identity a make or origin of this movement? The problem I am having is how to remove the suspension spring? Just can't seem to figure how its held in there. Seems to be pinned on both ends but pins are very tight. Just doesn't seem like they were meant to be removed. Also it came without its weight. What would be an appropriate size weight? Without the pendulum on a 2.75 lb weight from a Vienna Regulator seemed to run it fine. Case is quite unusual too. Only pictures I found online of similar style were of reproductions . This is definitely very old. Any ideas are appreciated. Thanks
