Pin Replacement
Discussion in 'Clock Repair' started by TEACLOCKS, May 15, 2020.
  1. TEACLOCKS
    TEACLOCKS Registered User
    Mar 22, 2005
    2,317
    77
    Clock service & repair
    Santa Rosa Calif.
    One pin on the pin barrel is broken.
    Would you replace with a tapered pin Or use brass spring wire so it would be straight ?
  2. Ed O'Brien
    Ed O'Brien Registered User
    Nov 30, 2009
    585
    Retired, and now full-time clock repairs.
    Winter Park, FL
    Not really sure, but I would be inclined to gently press in a taper so it would be secure. The taper would seem to have little effect in such a small size. Not sure how you would secure wire except with glue.
  3. shutterbug
    43,233
    1,191
    Yes, tap in a tapered pin of about the same size. You can use a little permanent LocTite if you want for insurance. Then you'll have to cut the pin to length.
  4. TEACLOCKS
    Mar 22, 2005
    2,317
    77
    Santa Rosa Calif.
    Thank you
    I was thinking Loctite
  5. klokwiz
    klokwiz Registered User
    Feb 4, 2009
    1,327
    56
    WRENCH
    Annapolis, MD
    Pins look like steel I would go with the tapered steel pin you could even square the part of pin that will stick out. first part is to get the broken part out and determine of you are dealing with hollow tube and how much surface there is to pin it to? Joe.
  6. TEACLOCKS
    Mar 22, 2005
    2,317
    77
    Santa Rosa Calif.
    The pins are brass.
    Punched in the old pin into the barrel.
    Taped in a new tapered pin. W/ loctite.
    Filed to the right height, cleaned up sides of pin.
    Looks good
  7. shutterbug
    43,233
    1,191
  8. klokwiz
    Feb 4, 2009
    1,327
    56
    WRENCH
    Annapolis, MD
    yes looks good, sorry the original photo looked steel. well done. Joe
