Pin pinion on Mauthe wall clock shaft
Discussion in 'Clock Repair' started by ringhilescu, Jul 13, 2019 at 6:15 PM.
  1. ringhilescu
    ringhilescu Registered User
    Sep 23, 2010
    12
    Good evening
    I have a Mauthe wall clock, 1926 manufacturing year. The problem I have been facing for 2 days is the next. When the bow of the gong returns, after about 2, 3 turns, in which it feels that the spring is tensioning, the sprocket 2, along with the spindle (3) on which it is fastened, performs a rotation motion, the spring deforms, while during that time , the pinion 1 remains motionless. It is perhaps unnecessary to say that the gong does not work anymore, as long as the bow can not be tightened. My questions are as follows:
    1. Is this piece, made up of pinions 1 and 2, a name of its own?
    2. How can this problem be remedied?
    3. The pinion 1 and the pinion 2 are fixed parts on the shaft 3?
    4. If the pinion 1 is a fixed part on the shaft 3, how does it lock on the shaft?
    I attach the picture.
    Thank you
  2. Willie X
    Willie X Registered User
    10,952
    431
    That would commonly be called the 2nd wheel assembly. It is made from only two pieces. The arbor and pinion is cut from one piece of steel and the brass wheel is permanently attached. Nothing is supposed to cause these pieces to move in relation to each other.
    Maybe you could explain more about the specific problem you clock is having?
  3. R&A
    R&A Registered User
    Oct 21, 2008
    3,980
    65
    Well for one thing there are names for 1 2 3 1 is wheel 2 is a leave pinion 3 is an arbor
    Wheels are staked to the arbor. In this case it looks to be staked to the top of the leave pinion which is part of the arbor. It is really hard to understand what you are asking.
  4. ringhilescu
    Sep 23, 2010
    12
    To be more specific, I attach and this video
    https://vimeo.com/user100789781/review/347980143/01ec282f39
    Thank You
  5. R&A
    R&A Registered User
    Oct 21, 2008
    3,980
    65
  6. shutterbug
    39,184
    448
    The spring added to the lower arbor is binding the upper one. Both should have the same type of spring as the upper arbor has....a wire return spring attached to the plate. If either pinion is turning independently, it's defective .... but that would be VERY unusual in this design.
  7. ringhilescu
    Sep 23, 2010
    12
    Hi
    I found the problem. I have to repress wheel 1 on the leve pinion 2. Is it a complicated operation? Can I do it home, or should I take them to a specialist? If this procedure can be done, exactly, what are the steps ?
  8. shutterbug
    39,184
    448
    You mean the pinion is turning on the arbor?
  9. ringhilescu
    Sep 23, 2010
    12
  10. shutterbug
    39,184
    448
    Yeah, it sure is! This usually indicates a cracked pinion, and the repair won't be easy. The pinion will need to be removed from the arbor and repaired, and then inserted again. If you could find a donor clock to take the wheel from, that would be easiest .... but it might be hard to find one. A clock repair shop with good equipment and skills could make you a new wheel with the pinion as part of the arbor. I think I'd go for that solution.
  11. Uhralt
    Uhralt Registered User
    2,805
    226
    I think the pinion is part of the arbor. The issue is that the wheel, that is staked to the pinion (like often seen in more modern clocks), has come loose and needs to be staked back on.
  12. shutterbug
    39,184
    448
    That is sure possible. Ring, can we see that wheel out of the movement from a couple different angles? You might be able to fix it if it's just a staking issue.
  13. Ravens_Time
    Ravens_Time Registered User
    Nov 26, 2016
    103
    Sumerduck, VA
    That barrel hook looks like its about to let go.
  14. Uhralt
    2,805
    226
    It looks like it has been struck from the inside by a broken mainspring. The broken spring also might have caused the damage to the wheel/pinion connection. Another possibility would be a failing click for the same symptoms.
