eclecticbeat
Hi All and Happy New Year,
This is only my second attempt at a torsion clock service and all beginner's luck has vanished. The first one was a relative's K und O Standard from the 50's. Just from reading the threads here and Terwilliger's Repair Guide, it went without a hitch and runs great! After performing all the normal tasks with this second one - I'm stymied.
Details:
Pin pallet, lantern pinions (c. 1913-1915 per JH)
Plate #1041
Pendulum #38 (has some lead inside I'm not sure should be there - easily removable but for now, it's in there)
Inside front plate, inside rear plate and bottom of pendulum are stamped 17001
Bracket/Saddle very similar to a #1
New Horolovar mainspring and suspension spring (.0038")
New Single tine fork (no binding I can detect)
All is clean/lubed and it powers up with a 1/4 turn of winding arbor
End shake feels good and there's no evidence of bent pivots
Beat is equal but not much overswing
Pallets look a bit tapered to me; wear marks on EW teeth seem to support that
Problem:
It just barely runs. 180~190 total rotation and I calculate it's losing about 1.5 hours in 24. I suspect the pin pallets but don't know if there's anything I can do with them.
According to 'The Book', the anchor pallets are not performing well at all. Drop is unequal and the pins are not drawn all the way to the rim of the wheel.
Measuring drop as the distance before a tooth falls onto a pin - the exit pallet drop is greater than the entrance drop.
The exit pin goes the deepest onto a tooth but only about half way down the tooth; entrance pin - not quite as far.
Are there any adjustments or did I miss something causing the pallets to act this way?
Couple of pics from the auction
Details:
Plate #1041
Problem:
