Picture Uploads
Discussion in 'Just Practicing and Learning' started by Kent, May 27, 2009.
  1. Tom McIntyre
    Tom McIntyre Technical Admin
    Aug 24, 2000
    82,536
    1,570
    176
    retired SW dev
    Boston
    Kent, see image namespace.
    For images that are not full color, it is best to copy and save them as .gif files, I think. That also allows you to give them a good title.
  2. Kent
    Kent Registered User
    Gibbs Literary Award NAWCC Fellow NAWCC Silver Member
    Aug 26, 2000
    18,390
    1,681
    I considered the file title that I had to be a "good title" (at least for the purpose of experimenting). Why didn't it work?
  3. Kent
    Aug 26, 2000
    18,390
    1,681
    #53 Kent, Jul 17, 2009
    Here's another one that didn't work.
  4. Kent
    Aug 26, 2000
    18,390
    1,681
    Lets try that again
  5. Kent
    Aug 26, 2000
    18,390
    1,681
    another one
  6. Tom McIntyre
    Aug 24, 2000
    82,536
    1,570
    176
    retired SW dev
    Boston
    I forgot to look at the name in the caption on the first one. If you save these black and white images as .gif files you won't have any problem loading them. I am surprised you are having a problem anyway.
    I changed the earlier name because the url I was looking at would not work for a name.
    For Encyclopedia images leaving the spaces in the name instead of inserting underscores make the names a little easier to read.
  7. Kent
    Aug 26, 2000
    18,390
    1,681
    I tried using spaces in lieu of underscores in attempting to upload one of these recent jpg files. It didn't work. I got the same "... must have the same name ..." error message.
    Having to go through all of my scans (the majority of which haven't been uploaded yet) and convert them to gif files (and upload some again as Encyclopedia images) is going to be a real pain in the butt and a discouraging factor in putting up new stuff.
  8. Tom McIntyre
    Aug 24, 2000
    82,536
    1,570
    176
    retired SW dev
    Boston
    If you are getting the name must match error message, you are not copying the name correctly.
    You don't have to convert to .gif, it just gives better performance both when uploading and when viewing the article using the image.
    When you are loading an image from an image site that has a database, the name will not generally be in the URL. For example the names are not in the URL of an image that has been uploaded to this web site as a post attachment. You have been uploading quite a few images as attachments, which puts the title and the file name in separate places.
    I created a directory on my desktop that I call file transfers and I generally convert the files and store them there with a useful name. Then I can reference those copies when building an image article.
  9. Kent
    Aug 26, 2000
    18,390
    1,681
    The files are on my hard drive. I copied file name from the folder list of files. I then pasted it into the "Title" box and, for good measure, I then pasted it in the "Message" box.
    I opened the "Managed Attachments" box and used the "Browse" button to open the folder list, from which I selected the file whose name I was copying and pasting.
    Finally, I clicked on the "Upload File from your Computer" button and got the "... must have the same name ..." error message.
    After several iterations with and without underscores, with and without the filename extension, I gave it up as a bad job and came here to continue uploading images.
    Obviously, I'm missing something simple. Although I'm not a computer whiz, I'm a long way from being computer illiterate. If I'm having trouble, other people who'll want to add images to the encyclopedia are going to have trouble also.
  10. Tom McIntyre
    Aug 24, 2000
    82,536
    1,570
    176
    retired SW dev
    Boston
    I am sympathetic Kent, but I do exactly what you just described and I have never had a failure. I mostly use Firefox, but I have done this with both ie and Firefox.
    Typically, I select the image file name from a directory listing and paste it into the title box of the Encyclopedia New Image form.
    I then click on the paper clip and navigate to the file using the browse button and double click on it. I then press upload and when the file is uploaded, I close the window on the attach dialog box.
    Next I close the edit window (sometimes I type in a further description of the file before closing the edit window. I do not try to use the ATTACH tag to insert the image in the image article.
    After I press submit, I see the completed image article.
  11. kirxklox
    kirxklox Registered User
    Dec 17, 2002
    4,387
    56
    Dardanell, AR
    I can think of several problems.
    Try renaming your file to something simple like:
    doc1001.ext
    Test this to see what your result is!
  12. Kent
    Aug 26, 2000
    18,390
    1,681
    Well ....
    I'm perplexed - it works now, both with Mistake and with 1926_Dec_Royal.jpg.
    Thanks for spending your time on what turned out to be a non-problem.
  13. Tom McIntyre
    Aug 24, 2000
    82,536
    1,570
    176
    retired SW dev
    Boston
    I installed an update about noon today that addressed poor handling of extra information on images. I still don't know exactly what got your files cross wise, and we may never know, but I am glad it is working now.
  14. Kent
    Aug 26, 2000
    18,390
    1,681
    Still had problems uploading in Wiki Images
  15. Tom McIntyre
    Aug 24, 2000
    82,536
    1,570
    176
    retired SW dev
    Boston
    There is a bug in the Encyclopedia software that causes names with ampersands to behave badly. Changing it to and worked fine.
    The article image is very large in terms of file size. It was over 216 kbytes after converting to .gif format.
    Both articles have been uploaded. I tried really hard to preserve your names this time, but I did convert them to .gif since it represents no additional effort after making the copy.
  16. Kent
    Aug 26, 2000
    18,390
    1,681
    Peoria
  17. Kent
    Aug 26, 2000
    18,390
    1,681
    Illinois
  18. Tom McIntyre
    Aug 24, 2000
    82,536
    1,570
    176
    retired SW dev
    Boston
    My edited version of your Peorias.
  19. Kent
    Aug 26, 2000
    18,390
    1,681
    Mont Type II
  20. Kent
    Aug 26, 2000
    18,390
    1,681
    #70 Kent, Aug 14, 2009
    Non-Magnetic Watch Co. of America Grades
    Grade No.SizeJewelsPlate FinishDescription
    211811Gilt11 Jewels (top plate) in Settings; Breguet Hairspring; Patented Micrometer Regulator
    251811Nickel11 Jewels (top plate) in Settings; Breguet Hairspring; Patented Micrometer Regulator
    321815Gilt15 Jewels in Settings; Exposed Pallets; Breguet Hairspring; Patented Micrometer Regulator
    341815Nickel15 Jewels in Settings; Exposed Pallets; Breguet Hairspring; Patented Micrometer Regulator
    431815Nickel15 Ruby Jewels in Gold Settings; Adjusted; Patent Regulator; Double Sunk Dial; Breguet Hairspring
    451815Nickel15 Jewels in Settings; Adjusted; Patent Regulator; Double Sunk Dial; Breguet Hairspring
    471815Gilt15 Jewels in Settings; Adjusted; Patent Regulator; Double Sunk Dial; Breguet Hairspring
    621618NickelFine Nickel Movement; 18 Ruby Jewels; Centre Jeweled; Exposed Pallets; Double Roller Escapement; Escape Wheel Cap Jeweled; Paillard's Patent Non-Magnetic Inoxydable Compensation-Balance and Breguet Hair-Spring; Non-Magnetic Escapement; Adjusted to Temperature, Isochronism and four positions; Patent Regulator. Hunting Only
    711620NickelBest Quality Nickel Movement; 20 Finest Quality Ruby Jewels in Gold Settings; Centre Jeweled; Exposed Pallets; Double Roller and Full Cap Jeweled Escapement; Paillard's Patent Non-Magnetic Inoxydable Compensation-Balance and Breguet Hair-Spring; Non-Magnetic Escapement; Adjusted to Temperature, Isochronism and six positions; Patent Regulator; Double Sunk Dial; finely finished throughout. Hunting and Open Face
    721618NickelFine Nickel Movement; 18 Fine Ruby Jewels in Raised Gold Settings; Centre Jeweled; Exposed Pallets; Double Roller Escapement; Escape Wheel Cap Jeweled; Paillard's Patent Non-Magnetic Inoxydable Compensation-Balance and Breguet Hair-Spring; Non-Magnetic Escapement; Adjusted to Temperature, Isochronism and four positions; Patent Regulator. Hunting and Open Face
    731616NickelNickel Movement; 16 Ruby Jewels in Raised Gold Settings; Centre Jeweled; Exposed Pallets; Double Roller Escapement; Paillard's Patent Non-Magnetic Inoxydable Compensation-Balance and Breguet Hair-Spring; Non-Magnetic Escapement; Adjusted to Temperature, Isochronism and three positions; Patent Regulator. Hunting and Open Face
    741615NickelFine Nickel Movement; 15 Ruby Jewels; Exposed Pallets; Double Roller Escapement; Paillard's Patent Non-Magnetic Inoxydable Compensation-Balance and Breguet Hair-Spring; Non-Magnetic Escapement; Adjusted to Temperature, Isochronism and two positions; Patent Regulator. Hunting Only
  21. Kent
    Aug 26, 2000
    18,390
    1,681
    PRR
  22. Kent
    Aug 26, 2000
    18,390
    1,681
    Non-Mag
  23. Kent
    Aug 26, 2000
    18,390
    1,681
    More non-mag
  24. Kent
    Aug 26, 2000
    18,390
    1,681
    more non-mag
  25. Kent
    Aug 26, 2000
    18,390
    1,681
    and 2 more
  26. Al Schook
    Al Schook Registered User
    Mar 30, 2009
    252
    Michigan
    Practicing....
  27. Al Schook
    Mar 30, 2009
    252
    Michigan
    Try to improve focus...
  28. Scottie-TX
    Scottie-TX Registered User
    Apr 6, 2004
    936
    Mesquite, TX
    Looks good ta me, SCHNOOK!
    How big is that wheel - 'bout .250 dia?
  29. Kent
    Aug 26, 2000
    18,390
    1,681
    Serial No.SeriesStyleSetAdjDamaskeening PatternComment
    829903OFPSAdj
    834015OF
    850209HC
    8542023OFAdjCircular
    8542213OFPSAdjCircular
  30. Kent
    Aug 26, 2000
    18,390
    1,681
    More non-mag
  31. Al Schook
    Mar 30, 2009
    252
    Michigan
    That is "The Schnookster" to you brother!! It is a Seiko crown and I was trying to see what I could do by taking a photo thru my magicdefyng glass. (Actually these were taken with a B&L hand triplet or doublet I don't know which or what diopter.) The guy pulled the wrong crown out of stock for the watch pictured. BTW, you are a veerry punny scooty! (hard to burr the rrr's in text) Bennet Cerf made a New Years resolution never to pun again. His friends locked him in a closet and refused to let him out until he spake said pun. After a long 2 or 3 second delay, Benny said; "O pun the door!"
    73 bro.
    (if you don't know what that means, I never said it)
    This is a test and only a test. If it had been something of a useful nature, it would have been some where else!
    I have attached a pic of the stem that the crown was supposed to go on .. some fun to get it to fit I recon. The crown can be seen as a blurry lump in the background, and a pic of the B&L's.
    Al
  32. Scottie-TX
    Apr 6, 2004
    936
    Mesquite, TX
    "73"? WHEW! Glad it wuzn't "88"
    Di dah dit.
    I think the longest recorded burst of continuous laughter by a comedian was during dead silence. George Burns, I think, when asked, at the point of a gun, "your money or your life!"
    A long time later after continuous laughter during his silence - that inimitable Burns expression and, " I'm thinking."
  33. Al Schook
    Mar 30, 2009
    252
    Michigan
    @ Scottie ROFL! better than some one writing SK about you in QST!
    Ruts.....(not animal or road) Ignore the cat hairs .. that is Maggie's contribution to my repairs...my 20 pound barn cat.
    Say; "Goodnight," Gracie!
    -> posts merged by system <-
    Ruts ... not so much...
  34. Al Schook
    Mar 30, 2009
    252
    Michigan
    A better picture of the "Rut"
  35. Kent
    Aug 26, 2000
    18,390
    1,681
    more non-mag
  36. Kent
    Aug 26, 2000
    18,390
    1,681
    Waltham Non-Mag
  37. Kent
    Aug 26, 2000
    18,390
    1,681
    More
  38. Kent
    Aug 26, 2000
    18,390
    1,681
    something else
  39. Kent
    Aug 26, 2000
    18,390
    1,681
    #89 Kent, Oct 2, 2009
    More
  40. Kent
    Aug 26, 2000
    18,390
    1,681
    #90 Kent, Oct 10, 2009
    still more
  41. Kent
    Aug 26, 2000
    18,390
    1,681
    still more
  42. Kent
    Aug 26, 2000
    18,390
    1,681
    Not finished yet.
  43. Kent
    Aug 26, 2000
    18,390
    1,681
    Hamilton
  44. Kent
    Aug 26, 2000
    18,390
    1,681
    Love those marginal minute dials!
  45. Kent
    Aug 26, 2000
    18,390
    1,681
    Dichotomy
  46. Kent
    Aug 26, 2000
    18,390
    1,681
    Dollar watches
  47. Kent
    Aug 26, 2000
    18,390
    1,681
    More
  48. Kent
    Aug 26, 2000
    18,390
    1,681
    Champion
  49. Kent
    Aug 26, 2000
    18,390
    1,681
    IWCCo
  50. Kent
    Aug 26, 2000
    18,390
    1,681
    Nickeloid
