Picked up at a sale any idea on maker and date
claussclocks
Mar 14, 2013
939
328
Texas
I found this languishing at an estate sale and decided to bring it home. Appears to be of older design but it has no trademark anywhere on it.
The number 77725 on the lower corner of the back plate and on the bottom of the pendulum are its only markings.
The dial resmbles a Phillip Haas if you look at the curling on the tail of the 7 but that's no sure thing.
Any suggestions or input would be welcome.
Excuse my messy bench. I didn't take time to photograph in a clean spot and I had to leave shortly
Thank You
David P. Clauss
KurtinSA
Nov 24, 2014
5,959
665
San Antonio, TX
Phillip Haas never made 400-day clocks...mentions of Haas in the repair guide should be changed to Hauck.
I don't have much to add. I have two clocks with a similar dial and pendulum with leader. But beyond that, there are differences. My clocks are a Kienzle (yours is not) and a Huber, which has a different back plate. My guess would be that yours is a JUF. Interesting that the adjuster weights are so far out...the wrong suspension spring must have been used.
Kurt
claussclocks
Mar 14, 2013
939
328
Texas
Kurt
Thanks for the update. I was going by the photos and associated names as you may have guessed. I haven't done anything with it yet but I'm sure I will have to check that suspension.
DPC
KurtinSA
Nov 24, 2014
5,959
665
San Antonio, TX
Does the pendulum have a matching number? What does the bottom of the pendulum look like?
Kurt
Ingulphus
May 29, 2006
750
19
Oakland, CA
A nice find! I also have two similar models, the one below and another with thin fluted columns. I believe this one is a JUF, but it's not in a good place to turn around and photograph the back plate. After I first received it and serviced it, it was one of the best timekeepers of all my torsion clocks, until something broke the dome from above and got small bits of glass in the movement. I disassembled it and gave it another thorough cleaning (and a new dome), but now it stops at about the same time every couple of days, and I've been far too busy with the "real world" to take it apart again - it may be the motion works, or a tooth that was deformed by a bit of glass. Still a favorite clock, tall with a simple elegance, and watching the twist extension revolving is very addictive!
etmb61
Oct 25, 2010
3,304
501
Mascoutah, IL
Thank You
David P. Clauss
View attachment 737431 View attachment 737432 View attachment 737433 View attachment 737434 View attachment 737436 View attachment 737437 View attachment 737438
That's a JUF clock. I have this one just like it, number 64014.
Eric
etmb61
Oct 25, 2010
3,304
501
Mascoutah, IL
Sure looks like it. Do you have any idea of when it was made and what the suspension spring thickness is.
I would say it was made sometime on 1908 from the sparse info that I have. As for springs, for any disk pendulum I'd start with 0.004", but you might need to thin a 0.0045" to get it right.
Eric
Schatznut
Sep 26, 2020
1,560
866
SoCal
David, please don't apologize for the condition of your bench! A messy bench is a busy bench. And a busy bench is a happy bench.
Staff online
181,391
1,582,702
54,791
LSZ
3,130
Swiss Fake by Kent
Top
